| Home > Help Needed / General Tech Chat > MOT question re headlamp flash | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
4th Nov, 2008 at 10:34:25am
Is headlamp flash required for MOT? On our 1998 mini the main beam works but the flash has packed up, and I'm wondering whether I should be arsed to find out what's wrong with it :)
4th Nov, 2008 at 01:18:55pm
nope. |
4th Nov, 2008 at 05:20:19pm
Check the fuses, the flash I think could be a seperate feed to the stalk than the normal main beam.
4th Nov, 2008 at 05:45:09pm
does the horn work? I think theyre on the same fuse |
4th Nov, 2008 at 07:24:40pm
Remember Neils car is an MPI Nic with LOTTTS of fuses, not just 6 like an older Mini!
4th Nov, 2008 at 07:29:29pm
Oh bugger me!
4th Nov, 2008 at 07:33:46pm
6!!!
4th Nov, 2008 at 09:21:26pm
my mini passed its first 2 mot's (with me) without flash turned out to be bent/ dirty contacts,
Yes i moved to the darkside |
5th Nov, 2008 at 09:48:30am
I had checked the fuses, although I'm not sure sure which (if any) affect the headlamp flash
![]() 2102 Posts Member #: 432 Post Whore Swindon |
5th Nov, 2008 at 10:09:06am
26 fuses!!!!!!!!! jesus christ!!!
5th Nov, 2008 at 10:26:19am
A1, B1 or C1.
5th Nov, 2008 at 10:33:20am
The headlamp levelling (B3) has got a fuse in it and does work |
5th Nov, 2008 at 10:37:50am
It's got headlamp leavelling! WOW!
5th Nov, 2008 at 01:47:06pm
i will check on autodata at work but my bet is b1 |
5th Nov, 2008 at 06:04:01pm
Im thinking D10 |
5th Nov, 2008 at 06:06:16pm
YOU SANK MY BATTLESHIP!! On 28th Aug, 2011 Kean said:
5th Nov, 2008 at 06:39:33pm
5th Nov, 2008 at 09:48:22pm
autodata doesnt even have the fuse box diagram for the later minis. that put that idea to rest. |
