Home > General Chat > using milling bits in a pillar drill
i have a big bastard of a pillar drill, and got loads of milling heads (with threaded ends)
can i use these in my pillar drill if i get an mt3 adapter? is it 3/8 whitworth?
I dont want to do any horizontal work, just want to be able to make a flat spots/spot faces on stuff like blocks etc
cheers
joe
dot see why not .
sweet, just found this too
http://www.axminster.co.uk/product.asp?src...NC&pf_id=21342&
I use these to hold the cutters:
http://www.axminster.co.uk/src/froogle/pro...llets-22057.htm
tomf
Member #: 1746
Kent
Sorry double post.
Edited by tomf on 16th Nov, 2008.
tomf
Member #: 1746
Kent
Yea there shouldnt be any reason why it shouldnt work, but adjust the pillar drill so its running at a slower speed as mills run quite slow.
i can knock it down to about 800rpm, and has a 950W motor, im working with cast iron, so should be ok i hope
Just take small cuts and slow feeds and you should be fine. Oh and if your can hook up some kind of lubricant/coolant even better. *wink*
well, i havent milled anything since first year uni 6 years ago, so today had a blast at milling my centre main cap
took most of the hump off using the angle grinder, leaving about 1 to 2mm to mill away
set the drill up with a compound table i got from axminster for about 70 notes, and set the drill to 120rpm
the drill:
results were great, i wasnt sure whether it would be up to the job of doing a mains cap, but it was no trouble at all to it, there was a little bit of chatter as the compound table was bolted tot he usual adjustable drilling table which was sturdy but not 'rock solid' so deflected a tiny but and gave a slightly rough finish, but lots of wd40 helped there and it wasnt anything a quick rub on a stone afterward couldnt fix
took a few vids
http://www.youtube.com/watch?v=BZ2d_AVygqU
http://www.youtube.com/watch?v=-5V3iBVNmgk
mic'd up the cap before hand and it hasnt deformed at all, the top is perfectly flat, and its the same thickness end to end (give or take a couple of though), all in all pretty pleased with myself haha
Edited by joeybaby83 on 6th Dec, 2008.
PaulH
Member #: 2340
Dublin Ireland
how come you took such a deep cut imo that is why you are geting so much tool chatter, Iwould recomend that you take several light cuts at a slightly higher tool speed you will get a much smother finish and a lot less tool chatter
On 17th Feb, 2009 Rob H said:
cheers paul, need all the advice i can get
Wow a scale model A series block, how long did it take you to make that? *wink*
heres a pic of the finish on the cap
what do you reckon? it was on 120rpm, what sort of speed would be best?
Edited by joeybaby83 on 7th Dec, 2008.
oh, also, what sort of end mill is best for this sort of work?
i have loads, some slot end, some with 4 cutting edges etc, all the gear no idea haha
tadge44
Member #: 2500
Buckinghamshire
It looks to me as if you were feeding too quickly from the tool marks on the job.As you dont have the power or rigidity of a proper mill, you have to go very slowly.
