| Home > General Chat > lambda Sensor gauge thing. | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
16th Nov, 2008 at 08:39:58pm
Hello.
16th Nov, 2008 at 09:03:54pm
£200 is around the going rate for a decent wide band sensor and gauge. The cheaper narrow band versions are no use at all Imo.
16th Nov, 2008 at 09:17:40pm
There is another option: http://www.14point7.com/.
Edited by jbelanger on 16th Nov, 2008. |
16th Nov, 2008 at 09:19:54pm
http://www.doyouneedabrain.co.uk/prices.htm On 26th Oct, 2004 TurboDave16v said:
16th Nov, 2008 at 09:21:14pm
wideband setups arnt cheap but worth every penny. No way i could have ran my engine like i do without my LC-1 :) turbo 16v k-series 11.9@118.9 :)
194 Posts Member #: 2873 Advanced Member Milton Keynes |
18th Nov, 2008 at 09:28:26pm
On 16th Nov, 2008 Sprocket said:
http://www.doyouneedabrain.co.uk/prices.htm Is this 1 of those diy installations or is it better to get it professionally fitted? And where abouts does every 1 fit their lamda sensor? |
18th Nov, 2008 at 09:47:34pm
Its Bat (Gav) on here that does them. Ive fitted my lambda on the turbo elbow. Edited by matty on 18th Nov, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Nov, 2008 at 06:43:35pm
16 Posts Member #: 4347 Member Highlands |
19th Nov, 2008 at 10:33:13pm
how much? hav i bought a load of rubbish then? I got a 4 wire lambda sensor for a renault off ebay for £12.50 british made as well (1 wire guage, 1 wire earth, 2 wires heaters for more accurate reading till engines warm). Then a decent old school pointy needle a/f ratio gauge from america off ebay for £40. thought that would do the trick. Should i have something different? |
19th Nov, 2008 at 10:35:20pm
19th Nov, 2008 at 11:16:40pm
On 19th Nov, 2008 Bat said:
Hi, It 2 wires, ignition positive and an earth. You'll need to weld a boss in your downpipe to mount the sensor in. I do those for £3. Mount the gauge switch on and enjoy!
Cheers, Gavin :) Gav would u need the motor out for fittin the lamda? sounds like i'll me pm'n u very soon , would these lamda's work with any gauge? i have an autogauge a/f gauge.
20th Nov, 2008 at 06:22:16pm
whats with the band thing then. I didnt really research it at all, just thought " it'd be nice to know when its running lean/rich without guessing and bought a sensor and gauge. Whats the benfits of wide band over narrow band, more range? surely narrow band tells you when mixtures ok, or is it just a rough average with narrow band. Thanks fir ur knowhow :) |
20th Nov, 2008 at 08:53:39pm
A narrow band sensor only works well around stoichiometric ratio, hence it has a narrow band of operation.
20th Nov, 2008 at 09:28:24pm
think i get it - basically the diyers version... like the differnce between an oil pressure light an an oil pressure gauge, one tells you when somethings wrong, other tells you whats actually going on.
20th Nov, 2008 at 09:31:56pm
ah i just looked at your afrs basically are you saying when your flat out and theres a lot of air (17) being sucked in and a relatively small amount of fuel (1), the wide band can still detect how much whereas a narrow band would be lost? |
20th Nov, 2008 at 09:44:24pm
a narrow band can only tell you 3 states, you either have a stoich ratio 14.7:1, less than that, or more than that. a narrow band wont tell you how much less or more.
20th Nov, 2008 at 09:48:42pm
GOTCHA. so either bin the setup, or take it down to my rollin road where they'll shove a wide band sensor up its arse, and tune it... then take note of where it sits at on my gauge straight after its been tuned and keep those readings in mind (ignoring the markings saying its too rich etc...) or am i still missing a trick
20th Nov, 2008 at 09:50:21pm
btw, i dont plan on tuning it myself, i'm just going to build it, roughly set it up, then get it tuned by the locals. I just put that gauge in to keep me safe, but it looks like it wont |
21st Nov, 2008 at 12:32:27am
Taking a note of where the narrowband gauge sits won't help because that will change with the temperature of the sensor and exhaust gas. So the AFR may be different and the gauge will still read the same.
21st Nov, 2008 at 08:13:05am
ok then, ill bin it an buy wideband setup, until then it can sit an look pretty in my dash :cool: thanks for all your help |
21st Nov, 2008 at 08:55:57am
Hmm this looks pretty interesting!
21st Nov, 2008 at 09:54:13am
This looks like the easier one to use.
21st Nov, 2008 at 11:27:39am
It does look very interesting - I wish I'd seen it before ordering all my stuff from TechEdge (which still hasn't arrived yet...)
21st Nov, 2008 at 12:03:31pm
The innovate software is great, that how me and Robert set mine up. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Nov, 2008 at 01:01:07pm
I think i might order the kit and buy the components.
