Home > Help Needed / General Tech Chat > cracked t2 turbo
turbominij
Member #: 2104
Essex - UK
this was started under show us yours but i thought it should move to here
old post
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=238967
the engine came out saturday for a leaking manifold gaskit. which i thought fair enought a bit of a pain but i can cope with that.
once the engine was out took apart all the turbo assembily and was cleaning manifold faces and my friend was looking over the turbo and found a big crack in the wastgate.
the crack runs from the outside edge to the wastgate port and then from the other edge of the wastgate port to the impeller port and is right the way through the casting.
so the car is off the road till i can arrange a replacement exhaust casing or replacement t2 turbo
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
mini93
Member #: 2017
Warwick.
used to see these cracked all the time...dont worry...when i got annoyed at them even belting them with a heavy fucking hammer they wouldnt smash off
David.
How do you people manage to take such crap photos? No offense, but the pictures you've provided are really useless.
turbominij
Member #: 2104
Essex - UK
i no i did not take the photos my mate did on a v old camera best he could get unforutnatly.
what do you guys recon im worried of using this turbo again because it has cracked between the wastgate and the impeller im worried if it colapses it will distroy everything i have worked hard on and paid good money on to get the engine to this point.
some opinions and advice please
i doubt a complete falure would do harm to anything other than the turbo bud
mines far far worse than that! they tend to crack very quickly then thats it.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
So they don't get the Vegard seal of appproval then?*hehe!*
On 7th Nov, 2008 Nic said:
naeJ
m
AHhahahahaa
Oh Vegard you do make me laugh
Jay#2
Member #: 648
Someone photoshop up a "Vegard seal of approval" picture that he can stamp posts with. Something involving aviator sunglasses....
naeJ
m
Mirage
Member #: 119
As Tom Jones would say "Its not unusual".
They crack here all the time, use it and keep an eye on it from time to time. If you get a rebuilt turbo look to see a new turbine casting has used.
I've ran cracked T2's never had a problem
turbominij
Member #: 2104
Essex - UK
ok thanks for the advice im a mate to take a look so will let you know the out come the turbo has only been used for 6 months which is the bit that worried me
If it is still providing the boost, then fit it back on and forget about it.
My T2 has the same crack, but I've not used it yet.
