| Home > Help Needed / General Tech Chat > KAD quickshift yes or no | |||||||
26th Nov, 2008 at 12:17:44pm
The gearshift in the mini does feel long, I am going to cut down the gearstick and see if that has a dramatic effect on how it feels, however was just wondering what peoples opinion of the kad one is.
26th Nov, 2008 at 12:23:39pm
Yeah i've got one, and would get one again if I had to but as with all the KAD stuff the price is quite a disadvantage!
26th Nov, 2008 at 12:26:28pm
Thanks, If I go for one it will be a KAD one. I will hopefully cash it in as a christmas present! On 7th Oct, 2010 5haneJ said:
26th Nov, 2008 at 01:45:15pm
i had/ have one in my off the road mini took some getting used to but gives it a nice short clunky feel Yes i moved to the darkside |
26th Nov, 2008 at 04:08:11pm
It improves the feel no end, first and third get quite close to each other, so does second and fourth but as people say you get used to it. It does require a little more effort to shift as the fulcrum is moved up but yeah it's a good buy alright. On 7th Nov, 2008 Nic said:
26th Nov, 2008 at 06:30:38pm
Sod it, I'm gonna go for it. Going halves with mum for christmas:) On 7th Oct, 2010 5haneJ said:
194 Posts Member #: 2873 Advanced Member Milton Keynes |
26th Nov, 2008 at 06:35:46pm
i got 1, very cool, and u get used to it |
26th Nov, 2008 at 08:38:16pm
think i have heard that these damage the gearbox somehow (maybe syncros). not sure if calver of someone said that, or how true it is. ta |
26th Nov, 2008 at 09:00:52pm
Cant really see how they would? It's the same motion as when changing with a normal gear stick |
27th Nov, 2008 at 12:35:41am
69 Posts Member #: 1670 Advanced Member |
27th Nov, 2008 at 01:09:13pm
i have the older style one, no lift up collar but i would buy one again, as everyone has said it takes a while to get used to but is soooo much better |
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
27th Nov, 2008 at 02:38:24pm
i brought a cheap one from some where like mini spares and to be hones it makes a difference but i had to modify it to fit properly i would by a proper KAD one if u going to get one at all Edited by turbominij on 27th Nov, 2008. "Tuning should be a compromise between what is possible and what is necessary"
27th Nov, 2008 at 02:54:29pm
On 27th Nov, 2008 turbominij said:
i brought a cheep So any transportation of cattle? I guess Jim would like this. On 13th Jul, 2012 Ben H said:
27th Nov, 2008 at 03:24:45pm
No, possibly if he brought a Sheep.
27th Nov, 2008 at 09:18:47pm
Vegard.
27th Nov, 2008 at 11:16:57pm
On 27th Nov, 2008 graemec said:
No, possibly if he brought a Sheep. If you're going to be pedantic make sure you're 'witty' comments hold water! Ohoh, I know it's spelled sheep..However, it's not cheap :) YOu pedantic bugger :) On 13th Jul, 2012 Ben H said:
27th Nov, 2008 at 11:24:45pm
wooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Edited by James_H on 27th Nov, 2008. |
28th Nov, 2008 at 07:39:03am
Don't mess with the V, he has better english than me (wait that rhymes...). Plus he was pointing out the use of the word bRought which can be difficult to cope with when you have such good command of the english language. On 7th Nov, 2008 Nic said:
103 Posts Member #: 2314 Advanced Member cumbria |
28th Nov, 2008 at 07:39:11pm
I would fit 1 to any mini i have nwn There fantastic. Ive got 1 on my gt with 6 gears and its still simple enough to use once u get use 2 it. |
re-correction
