| Home > Ebay items For Sale > Or as I like to call it a spring | |||||||
14th Dec, 2008 at 04:57:15pm
http://cgi.ebay.co.uk/Classic-Mini-Superfl...A1%7C240%3A1318 On 17th Feb, 2009 Rob H said:
14th Dec, 2008 at 05:07:04pm
14th Dec, 2008 at 05:11:59pm
TD hates these lol
14th Dec, 2008 at 06:03:29pm
"can select reverse without pumping till your blue in the face"
Edited by James_H on 14th Dec, 2008. |
14th Dec, 2008 at 09:24:58pm
bargain! "Turbo's make torque, and torque makes fun"
15th Dec, 2008 at 09:30:41pm
That fucking spring is pointing the wrong way... What a load of crap! On 17th Nov, 2014 Tom Fenton said:
15th Dec, 2008 at 09:46:21pm
Dave, I know we've discussed this before. If the spring on the slave is fitted the other way, won't the clutch bearing take a hell of a beating? On 13th Jul, 2012 Ben H said:
16th Dec, 2008 at 08:03:21am
Get to doctors mate!
On 14th Dec, 2008 James_H said:
"pumping till your blue in the face" 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16th Dec, 2008 at 11:09:13am
lol
16th Dec, 2008 at 11:21:23am
I cant bleve somone gave him 10 quid for that Im going down to the garrage to find any piece of crap in my tool box and call it an MED/AP raceing yoke stick it on ebay and bobs your uncal all my money wores will be over :) Edited by PaulH on 16th Dec, 2008. On 17th Feb, 2009 Rob H said:
315 Posts Member #: 3013 Senior Member Epsom Surrey |
16th Dec, 2008 at 12:34:59pm
did anyone notice the over expensive postage of 6 quid???
16th Dec, 2008 at 12:38:53pm
Its not even a threaded to stop?
16th Dec, 2008 at 12:52:58pm
hahah that makes it even worse then your paying 10 pound for a spring then 6 quid for postage!!!
16th Dec, 2008 at 12:59:06pm
a spring that is that dose fuck all bar making the car hard to get gear with I love the human race :( On 17th Feb, 2009 Rob H said:
16th Dec, 2008 at 02:26:25pm
On 15th Dec, 2008 Vegard said:
Dave, I know we've discussed this before. If the spring on the slave is fitted the other way, won't the clutch bearing take a hell of a beating? No, In short, if a bearing is rated for (say) 8000lbs intermittent load which I suspect the standard bearing is, then (as a rule of thumb) loading it up with between 1% to 4% of the max rated load will in theory have an infinite life. Consideration though, needs to be given to minimum load for the operating conditions; In that if there is unsufficient load to overcome the lubricant viscosity (also considering cold temps) then the bearing elements will slide, not roll. That is never good for bearings! Not usually a problem for most applications of our vehicles to be honest! On 17th Nov, 2014 Tom Fenton said:
16th Dec, 2008 at 03:24:04pm
Does speed not come into account Dave? So even if it is only taking a small load, but at high speed? It has been ages (in fact in uni) since I did any bearing calcs.
16th Dec, 2008 at 04:37:56pm
well, yes - but I'm assuming the bearing is rated for the speed it's intended to be used in... I can't imagine a small bearing like the release bearing having a problem with speed; remember every release bearing you come across these days is sprung-loaded against the diaphram. On 17th Nov, 2014 Tom Fenton said:
hehe
