Home > Technical Chat > Re-positioning the alternator
boldy
Member #: 2464
Weston-Super-Mare
As the title states.
Looking to give more room at the front of the engine so looking to re-position the alternator towards the back of the engine bay.
Ive been told it can be done but ive found nothing on the web on how.
Can anyone help?
have you looked at the nippon denso alternators? alot smaller than the standard item and a damn site easier to fit than moving your alternator to the back.
there are alot of people here packing alot into the fronts of round nose minis, and using the nippon alternator.
how much room do you need? and what do you need it for?
picky
Member #: 632
York, UK
remember an alternator unlike a dynamo can be spun in either direction and still produce power. Can sometimes be useful if you want to move it somewhere else.
evolotion
Member #: 83
Glasgow, Scotland
like the honda engine boys do where they mount the alternator into the inner wing where a side mount rad would normally reside!
Denis O'Brien.
Mikes1098
Member #: 2190
South Carolina, USA
Does anyone have pictures of a nippon denso alternator mounted... the one that James mentioned?
philc
Member #: 1346
bromsgrove
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2995
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
http://www.turbominis.co.uk/forums/index.p...id=174742&fr=75
http://www.turbominis.co.uk/forums/index.p...id=225814&fr=50
On 30th Apr, 2010 Rod S said:
Gary's description is best
Mikes1098
Member #: 2190
South Carolina, USA
Awesome, Thanks!
antman
Member #: 358
Snetterton, Norfolk
Another thing to bear in mind is that some formula type cars like formula fords have the alternator belt driven from the inner cv joints although this will turn it a lot slower.
hario
Member #: 2885
I changed my altenator the other day and had an idea which seemed to work. Just unbolted it then reattached but turned 180degrees so the adjustment hole was at the top and the altenator was just behind the curve of my round nose bonnet,would need to make an adjuster for it though, along with the other clearance issues.
Any pics?
