| Home > Help Needed / General Tech Chat > starter query | |||||||
60 Posts Member #: 4055 Advanced Member teeside |
30th Dec, 2008 at 12:00:50pm
hi could anyone please tell me if they have had any problems with swapping starters the original starter for my engine had the separate wing solenoid but i replaced it with a starter with the solenoid built onto it i have read this is ok but can be a little noisey the problem im having is that every so often the starter just clicks i have to remove starter then refit then all is ok for maybe couple of weeks is it possible the cog on starter is not returning after starting and is there any way to reshape starter cog with a grinder has anyone else had this problem ? any info greatly appreciated hope everyone has a great new year |
30th Dec, 2008 at 12:43:55pm
"reshape starter cog with a grinder"
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
30th Dec, 2008 at 01:09:25pm
Did you read it was ok on TMF or Minifinity?? Edited by Dicanio on 30th Dec, 2008. |
30th Dec, 2008 at 01:11:24pm
I doubt if anything has changed since you first asked...
30th Dec, 2008 at 01:49:26pm
30th Dec, 2008 at 04:42:01pm
Pre engaged starter on an inertia ring gear can and does work, but requires a spacer that Rod S mentioned. However, the problem you experience is a side effect of this combination. It is far from ideal as you have found.
30th Dec, 2008 at 05:20:57pm
I have a verto ring gear, and tried this with an old starter. That went solid On 13th Jul, 2012 Ben H said:
30th Dec, 2008 at 05:36:31pm
it doesnt work the other wy round IE Verto ring gear and inertia starter.
30th Dec, 2008 at 07:08:54pm
thing is, a brand new non-verto starter is only £20 new! |
559 Posts Member #: 2775 Post Whore Aberdeen |
30th Dec, 2008 at 07:42:51pm
Did you read it was ok on TMF or Minifinity?? What you mean there is more than one mini site? Trust me to get stuck on here reading duff info when I should be on the other ones! Dont suppose anyone can tell me how to put a 12" Subwoofer in my rear bins?? LOL |
30th Dec, 2008 at 07:47:06pm
yeah easy, smash it up with a big hammer and it will fit in there easy |
30th Dec, 2008 at 07:49:15pm
Great thanks! How big a hammer? its for 150w woofer? |
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
30th Dec, 2008 at 08:11:12pm
Verto---none Verto
30th Dec, 2008 at 09:14:16pm
on minifinity you can do all sorts of magical stuff with a grinder like turning down your own discs on car, were just not as 'hands on' on this forum... "Turbo's make torque, and torque makes fun"
30th Dec, 2008 at 10:37:14pm
People on this forum tend to spend to much time and money to cut corners.
