Home > Wanted > Oil cooler thermostat
tadge44
Member #: 2500
Buckinghamshire
Can anyone point me in the right direction to find a thermostat for my oil cooler,please ?. Im looking for one that fits as a sandwich plate between the filter head and body if poss.
loads on ebay. Been a few posts on these over the last few days. Use the search button...
Think Automotive do them IIRC
Scruffy
Member #: 328
Seaford Rise, South Australia
I bought a sandwich plate type from Merlin - about £44.00 inc the fittings IIRC
You can just see it here
Edited by Scruffy on 2nd Jan, 2009.
On 5th Sep, 2011 Vegard said:
Thats what i got for mine.
http://cgi.ebay.co.uk/OIL-COOLER-PLATE-THE...A1%7C240%3A1318
Rick
80 degrees is bit low isn't it??
tadge44
Member #: 2500
Buckinghamshire
Thanks, everyone.From your post cossierick do I infer that the VW will fit, or was it just by way of illustration -they dont seem to have one specific to an A series ?.
Scruffy
Member #: 328
It quotes a thread size of 3/4 UNF and I think you will have to use a smaller filter - as I said I use Ford Ka halfords own as champion is too large - don't know what size the Motorcraft (OE FORD) filter is
HOF264?
Thats the exact one i got and yes the 3/4 thread is whats needed.
Ive also got a standard filter on aswell.
Il try and find a pic?
Rick
Scruffy
Member #: 328
Rick
Is that with the standard front subframe or in your case the bit that is normally there on a steel car?
Nick i still have the standard mk1 front subframe built into the frame.
Rick
Rick
rick, can i ask why you left the remnants of the subframe?
Joe, can of worms mate.lol
Basicly i was just having a multipoint cage welded in the mk1 shell i had, but the sugestion of a spaceframe made me ask the question on how much more so the decision was made.
Then as the the car was just going to be built as a general toy the brief was given to keep all mini suspension pick up points as they should be to keep the cost down so in theory all there was to do is join up the dots with tube.
The reasons for the spaceframe is one, it was nice to be different and two, i wouldnt have to weld up another old rusty mini 5yrs down the line.
Obviously thinking about it i could of moved suspension points or used somthing different and made it out of different more up to spec for racing tube aswell.
Rick
