Home > A-Series EFI / Injection > Wiring colour coding for injection etc.
Tonight's silly question.......
Is there any "industry standard" for main colour / trace colour of the various bits used on modern fuel injection and engine management systems ???
I have the Lucas spreadsheet for all 70s/80s models so it covers all the stuff on earlier minis - along with every other Lucas equiped car of that vintage - but obviously doesn't cover modern ancilliaries.
I have a feeling there isn't a standard as I've been through Ford's TIS just to see what colours they used for the EDIS/coilpack wires and there are at least three variations depending on the car it was fitted to....... but some of you may know better.
I'm about to order up a load of cable/connectors to make my injection (etc.) loom so thought I would standardise if there is a standard to work to :)
jbelanger
Member #: 831
Montreal, Canada
I think the standard is to ignore whatever has been done before. :)
Seriously, to make it easy on you just chose whatever reference makes more sense to you (Rover, Ford, Megasquirt, ...) and use it. Yours may become the new standard for the future injected 5-port engines.
Jean
http://www.jbperf.com/
I used a Rover MPi loom so my colours are to that spec.
Bosch or 80s Ford would be a good choice, but not to go with the British standard wiring car loom!
I kept to Rover colours where I could, then where there were extra wires or clash of colours I made it up as I went
One thing I did for the injectors and the coils as I have a wire for each going back to the ECu, I used a base colour then from cylinder one to cylinder four, the tracer colour was, red, yellow, blue, green. Makes it a bit easier.
You could keep all the sensor grounds one colour, the each sensor has a base colour the same with a different tracer and so on. So as long as you know what base colours you used for which system, you can read the loom just looking at it *wink*
Make it easy for yourself, use the base colours as discussed then use the tracer colour again, as discussed*happy*
Edited by Sprocket on 13th Jan, 2009.
Thanks all,
For consistency, I'll use the Rover MPI as the base and add additional tracers (as per Sprocket) where I have more wires.
Mind you, Rover are hardly consistant.... I've just printed off the engine management diagrams for MPI and found three places where they change a wire colour half way along its run :)
On 13th Jan, 2009 Rod S said:
Thanks all,
That is usualy for a reason. such as the imobiliser system. Its there to try and confuse the average person making it just that bit more cificult for them to try and get round the system.
Where the lambda sensor is concerned, well that generaly changes colours at the connector of the sensor itslef.
Thing is, its your loom and you may be constructing it from scratch, so you can do away with those confusing little oddities.
Well I've ended up with ~70% use of the MPI colours and where there were anomilies I've created my own logic partly from the MS sketch and partly trying to add some meaning to the base colour and trying to avoid any conflicts with the old 70's loom colours (Lucas' old standard) which the rest of the electrics will retain.
The thing that annoyed me most was that I've had to order the new modern "thinwall" wiring to get the choice of colours/traces needed. I really don't like that stuff *frown*
I said it before and I will say it again. Thin wall wiring has a higher current rating and weighs less*happy*
...... and is totally suited to modern cars where every run of the loom has been computer analysed against rubbing/chaffing/resting on sharp edges and where the cost of copper is important..... and is totally UN-suited to project builds where runs (and where they lay) are "questionable"....
God knows how they get those current ratings anyway, they must assume every adjacent wire in the loom is doing nothing :)
Or the PVC covering is so hard (which is why I hate it) that it won't melt at any temperature :)
