| Home > General Chat > Welding brass??? | |||||||
25th Jan, 2009 at 06:04:50pm
Friend of mine into restoring Triumph TR's has just been onto me, wants to know if you can TIG weld brass, short of having a try at it I've no idea, I'm assuming he must have something wanting repair, anyone know??
25th Jan, 2009 at 06:09:52pm
yep,
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
25th Jan, 2009 at 06:12:16pm
Think you can mig or tig weld it, but depending on what type of brass will determine how easy it is I think.
25th Jan, 2009 at 06:12:51pm
isnt it much easier to braze it? not like its strong anyway! |
25th Jan, 2009 at 06:13:03pm
Its easier to silver solder if you have access to oxy/acet and a neater job too
I seriously doubt it! |
25th Jan, 2009 at 06:43:20pm
Cheers chaps, I haven't got any oxy kit so its TIG or nothing, I'll see what it is he has got, interesting though that you say DC Joe, I'd have thought AC from first guess being as its non ferrous.
25th Jan, 2009 at 07:40:30pm
How big/ small is it? You could send it my way for brazing at a small charge On 26th Oct, 2004 TurboDave16v said:
25th Jan, 2009 at 07:47:27pm
Depends if it cast or plate/tube.
25th Jan, 2009 at 08:09:03pm
Brazing takes place above 455c where as soldering takes place below 455c. The term brazing encompasses many different filler rods.
25th Jan, 2009 at 08:15:31pm
On 25th Jan, 2009 Tom Fenton said:
Cheers chaps, I haven't got any oxy kit so its TIG or nothing, I'll see what it is he has got, interesting though that you say DC Joe, I'd have thought AC from first guess being as its non ferrous. First, I very much doubt if you can "weld" brass - solder, or silver solder (and maybe braze) would be my choice. Second, the reason for having to use AC with TIG for aluminium has nothing to do with it being non-ferrous, it's because aluminium generates a very small but dense oxide layer on its surface. "Rust" if you like, but "aluminium rust". It is very dense and fucks up welding, so by using square wave AC to weld with TIG, one half of the AC pulse blasts the oxide off the surface, and the other half of the pulse welds.... On a decent TIG welder with AC, the forward/backward pulse can be varied, so altering the ratio of "clean" to "weld", because the requirement varies with the thickness of the aluminium...... Schrödinger's cat - so which one am I ??? |
25th Jan, 2009 at 10:40:57pm
Tom, ive use tig AC with brass brazing rods, it flows more than stainless but still did the job, |
27th Jan, 2009 at 10:56:24pm
Silver soldering is deffiantly lower temp than brazing
On 25th Jan, 2009 Sprocket said:
Brazing takes place above 455c where as soldering takes place below 455c. The term brazing encompasses many different filler rods. Silver solder despite what the name suggests has a working tempreature above 455c therefor is infact 'brazing' ![]() On 19th Jan, 2010 wil_h said:
27th Jan, 2009 at 11:28:45pm
27th Jan, 2009 at 11:33:14pm
Fook knows....but I know its alot lower than brazing. I haven't a god damn clue what temp it is! lol
27th Jan, 2009 at 11:35:05pm
isnt silver soldering a lower temp than normal soldering?
27th Jan, 2009 at 11:37:00pm
depending on the content of silver. silver solder flows between ~550c and 850c
27th Jan, 2009 at 11:37:01pm
Last time I done it, was with burner bars for a gas stove. On 19th Jan, 2010 wil_h said:
27th Jan, 2009 at 11:38:02pm
no no no no, silver solder is a brazing alloy therefore above 450c On 26th Oct, 2004 TurboDave16v said:
27th Jan, 2009 at 11:40:51pm
it might be sprocket...all I'm saying is its lower than conventional brazing....which could be 500c for all I know Edited by Jason G on 27th Jan, 2009. On 19th Jan, 2010 wil_h said:
27th Jan, 2009 at 11:55:19pm
28th Jan, 2009 at 07:17:58am
I showed the item in question the TIG torch and it turned into a lump of molten bobar on the bench, no suprise there then! He has access to a lathe so is going to buy a lump of brass and make a new one, they were fixings for a period radio!
28th Jan, 2009 at 10:36:34am
Yep no surprise. I would expect it to be more difficult to controll the heat with the tig. With oxy acetylene, you can adjust the heat while watching the colour of metal, you can then see the solder flow. Perhaps you could compare tig welding on brass to arc welding on thin sheet steel. While it can be done, its more probelmatic that its worth.
28th Jan, 2009 at 12:19:19pm
It is for a car radio, to fit his TR4A!
28th Jan, 2009 at 02:35:43pm
On 28th Jan, 2009 Tom Fenton said:
It is for a car radio, to fit his TR4A! cool! Has it got an 8 track? :) On 26th Oct, 2004 TurboDave16v said:
28th Jan, 2009 at 04:28:42pm
No, LOL!
and its really for an art deco radio
