Home > Help Needed / General Tech Chat > vacuum problem
kerwin12
Member #: 2244
mulbarton, norwich nr14 8gs
hello all.
i have searched tm but cant seem to find the answer i am looking for, so if any of you guy could help i would be really gratefull.
i have just changed the gaskets on the inlet manifold as they were leeking, but now there is so much vacuum my d/v doesnt work, at idle if you take the hose to the d/v off and put your finger on it, there is so much vacuum i could hoover my interia with it? it is connected in the right place and i cant find any leeks, and shorly if it was leeking there would be less vacuum?? any ideas?
high vacuum at ldle is a good thing.
Im not sure what you are trying to say. But high vacuum and high boost on a closed throttle will open the dump valve
faulty dump valve the diaphram may have gone ?
What type of DV is it?
kerwin12
Member #: 2244
it is a diaphram d/v. i have had it apart and there doesnt seem to be any thing wrong with it. i took it for a drive this mnorning and it was working it first and second gear but not in third or forth? *Confused*
I don't understand. The vacuum is needed to open the DV. So at idle it should be open.
If you rev the engine it should start to close, but it won't close fully until there is some boost, and for this you wil need to be driving.
turbominij
Member #: 2104
Essex - UK
that is very strange that it would work in first and second but not the others
my dumpvalve does not operate when yo are stationary reving the engine but does when you drive
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
at idle it would be closedunless the plenum pressure exceded the spring pressure minus the vacuum. so if the spring pressure was equal to 100kpaG and the vacuum was 30kpaA the plenum pressure would have to excede 30kpaG to open the valve.
At full throttle full boost there is almost boost pressure in the manifold and on top of the diaphragm and boost pressure below the diaphragm, almost cancelling out leaving the spring pressure holding the valve closed.
Suddenly close the throttle from full boost full throttle, plenum pressure rises, manifold pressure falls into deep vacuum and the valve opens quickly to dump the excess plenum pressure.
Again it depends how the valve has been installed as you can use the DV as a boost control or a Dump
Well mine are always open at idle.
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
er, just out of interest should i be geting a dumpvalve whooosh from a standard dumpvalve? sorry to hijack *blush*
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
I supose it depends what the plenum pressure is?
http://www.balancemotorsport.co.uk/main.as...ages=dumpvalves
