| Home > Technical Chat > rolling road/ dump valve | |||||||
15 Posts Member #: 4941 Member |
3rd Feb, 2009 at 03:47:20pm
hi
3rd Feb, 2009 at 03:51:20pm
A picture would work wonders here.......
3rd Feb, 2009 at 06:02:43pm
yea the pipe from the plenum? its already been modified and has been blanked off.
3rd Feb, 2009 at 06:41:08pm
The small pipe from the plenum is usually used to feed a pressure signal to the fuel pressure regulator.
Edited by Kean on 3rd Feb, 2009. |
3rd Feb, 2009 at 07:06:52pm
but generally boost gauges sense vacuum too... |
4th Feb, 2009 at 10:08:00am
You really want the dump valve trigger and the boost gauge pipe to come from the inlet manifold.
In the 13's at last!.. Just |
4th Feb, 2009 at 11:33:35am
Does this help?
On 7th Nov, 2008 Nic said:
9th Feb, 2009 at 01:03:02pm
hi
9th Feb, 2009 at 01:06:41pm
The experts will tell us, soon,I guess, but I suspect that either the dump valve or its associated pipework is undersized,or the vacuum signal is inadequate in some way.The dump valve should release the pressure quickly enough to stop any flutter, thats one of its uses. |
9th Feb, 2009 at 01:22:19pm
I still get flutter and a dump.
9th Feb, 2009 at 03:40:31pm
i get a flutter then a few seconds later it dumps slowly? have got printouts from them with the car will give them a call.
9th Feb, 2009 at 10:49:13pm
10th Feb, 2009 at 02:06:24pm
On 9th Feb, 2009 wil_h said:
I still get flutter and a dump. prunes ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
