Home > General Chat > Brakes - Diagonal Split System
MarkGTT
Member #: 1194
Shropshire.
Hi, im using a Diagonal Split System for the brakes, no servo, ap yelloy tag master.
Should i be using a bias valve or some kind of reducer for the rear brakes??
if so what should i be using? buying? What’s the easiest option?
Im hoping not as i don’t fancy changing it for a while..
cheers.
Ooh nasty nasty nasty *oh well*
Think about converting to the much safer front rear split *wink*
Edit, I didnt think you could use the yellow tag cylinder on a diagonal split as one circuit will get more force than the other giving uneven braking. Does your car crab under heavy breaking?
Edited by Sprocket on 6th Mar, 2009.
MarkGTT
Member #: 1194
Shropshire.
havent used the car yet or have fluid in the lines.. thought i would ask before bleeding it.
Why is the diagonal system not as safe as the front rear split?
cheers.
you're braking on opposite corners, so the braking force is not distributed accross the axle and you end up with wheels turning at differnet speeds forcing the car to turn or crab or worse.
I had an old range rover with a shot front wheel bearing. If you braked hard, that wheel would lock up and the car would go very quickly onto the wrog side of the road. not fun!
MarkGTT
Member #: 1194
Shropshire.
oh shit.
looks like im pulling it apart then.. just what i wanted to do.
so what do i need to buy to convert to a front rear split... some kind of bias valve that sits between the front and rear?
Nick
Member #: 154
Midlands
there's a thing that sits on the bulkhead that both lines go into then split front/rear, PDWA or something its called and its fupping mega £££ to buy new. might have one kicking about though in me garage.
MarkGTT
Member #: 1194
Shropshire.
yeah did some reading on this last night.. its about £70 - £80..
i have one on order, but cheers for the offer.
although thats shit, its the time i now have to take to redo the brake system im really fecked off about!!.. oh well you live and learn.
better to spend a bit of time and money now than to have an accident in your freshly fettled car...
MarkGTT
Member #: 1194
Shropshire.
very true mate, its a good job im doing it now before it was out on the road..
It's also far too nice a car to stick into a ditch with out a good excuse *happy*
This belongs in the bin!
Yes dont bother with that carbuncle!!
Consider getting a bean can style master cylinder that has one outlet, then use a T piece to split between the front and the back.
Then get a bias valve for the back brakes and robert is your mothers brother
Strange, I couldn't see the family resemblance when I met him a couple of weeks ago?
Edited by Bat on 7th Mar, 2009.
would that not mean if one brake is lost due to a leak all 4 are lost, would a yellow tag master cylinder not be better with front /rear split and then a bias valve on the rear line?
i ask mainly cos thats what i had planned,*happy* i have not bought my new master cylinder yet so just wanto be sure before i do*happy*
Yes it does-but at least you will die happy
rofl *hehe!*
