| Home > Technical Chat > Motorbike throttle bodies (carbs) and webber manifolds??? | |||||||
108 Posts Member #: 2464 Advanced Member Weston-Super-Mare |
7th Mar, 2009 at 08:45:27pm
Ive been hunting around to find out about who does kits for converting to bike throttle bodies but no such luck so far. Which leads onto my next question. Can you use 2 motorbike throttle bodies on a webber manifold?
7th Mar, 2009 at 08:49:12pm
Wont you be missing a vital component of the combustion prosess? Fuel?
7th Mar, 2009 at 08:51:19pm
Surely running say 2 bike carbs would work? |
7th Mar, 2009 at 08:54:24pm
Bike carbs yes. Throttle bodies are used for air control on a fuel injected setup.
7th Mar, 2009 at 08:56:05pm
ok. So can i run twin bike carbs on a webber manifold? |
7th Mar, 2009 at 08:58:22pm
i believe alex1340 is having a manifold built for his bike carbs by bogg brothers??
7th Mar, 2009 at 08:59:32pm
Tried it and didn't com up with much |
7th Mar, 2009 at 09:04:08pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=259505 |
7th Mar, 2009 at 09:08:33pm
thats the link i was looking at. There was a website where you could get the kits from and i can find it. There was once a couple of pages in a mini mag with it too, but cant find the magazine. THink it could be an interesting concept to get working. Think it could work. Just cant justify the amount of work bonnet wise to get a webber in. Carbs are neater and smaller. Plus give better results |
7th Mar, 2009 at 09:15:01pm
Please write Weber. That's what it's called. On 13th Jul, 2012 Ben H said:
7th Mar, 2009 at 09:53:39pm
No I think your geting Confused.com there Webber Wrote Musicals not Manifolds
On 7th Mar, 2009 boldy said:
ok. So can i run twin bike carbs on a webber manifold? On 17th Feb, 2009 Rob H said:
7th Mar, 2009 at 09:55:12pm
On 7th Mar, 2009 boldy said: did not think they affected the bonnet?, weber's are carbs Just cant justify the amount of work bonnet wise to get a webber in. Carbs are neater and smaller.
Plus give better results better what? every thing is a compromise depends what you want out of it but each to there own8-) Yes i moved to the darkside |
7th Mar, 2009 at 10:00:29pm
Working from a eaton 45 ive seen a few mini's having to make bonnet mods
8th Mar, 2009 at 05:38:24pm
On 7th Mar, 2009 boldy said: ok. So can i run twin bike carbs on a webber manifold?
9th Mar, 2009 at 01:10:51pm
Below is what i was on about with webers and bonnets etc
9th Mar, 2009 at 02:58:08pm
if you made a manifold that tucked it under the wing insted of over the top then you wouldnt need mods. downside is it would probably mean an longer manifold (bad) and a more bendy one (bad) but it would 'work'. They normaly hang SU,s right down the front on the end of a pipe for gods sake! |
9th Mar, 2009 at 05:47:08pm
On 9th Mar, 2009 boldy said:
Below is what i was on about with webers and bonnets etc http://www.flickr.com/photos/28332624@N07/3341417106/ On 11th Feb, 2015 robert said:
