| Home > Technical Chat > T25 vs T2 vs GT17 | |||||||
16th Mar, 2009 at 10:53:30pm
Bit vauge, as i havnt really delved into the depths of posibilitys when it comes to turbo selection yet, so I guess this call for me to learn!
16th Mar, 2009 at 11:08:25pm
Rich, im pretty sure they all use 4 bolt turbo/manifold flange, the gt17/t2 are the same size, but im pretty sure the t25/t28's use a slightly bigger flange, im sure someone will correct if wrong
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
16th Mar, 2009 at 11:26:57pm
i no the mirage manifolds accept both t2's and t25's so they must be the same flange fitment (4 bolt turbo/manifold flange) "Tuning should be a compromise between what is possible and what is necessary"
16th Mar, 2009 at 11:31:51pm
iiiiiiiiiiinteresting! I got a bit excited then at the prospect of only have to buy a manifold and elbow before I can run T25 but just double checked on a search and found this thread:
16th Mar, 2009 at 11:58:57pm
Scrap what i said if you dont want fabrication.
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
17th Mar, 2009 at 07:59:23am
Rich I would go for the GT17. Its a more modern turbo with lighter internals and better efficiency but as you say it involves more fabrication work,sooooo its still pretty much up to you mate.
17th Mar, 2009 at 08:16:52am
Im amazed at the size and weight difference between the T3 and the GT. The Gt looks tiny compared to the t3! Im slotting my holes on the GT to fit the T3 manifold just like Robert has. I have also bought a Saab downpipe for £12 so its not that hard really, im also going to open out the inlet hole on the turbo to suit the more sqaure T£ Manifold. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
17th Mar, 2009 at 08:30:21am
I would go GT17 without a doubt, alot more modern and efficient and they love boost aswell! :) https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th Mar, 2009 at 09:13:25am
What sort of boost level can the GT17 supply up to comfortably? I'm sure i've seen someone on here pushing 26psi?? Would this be out of the turbo's comfort zone? If something is worth doing, it's worth doing half of. |
17th Mar, 2009 at 09:58:30am
The GT17 sounds like the plan then! I was curious if the '25 would be any good as its convinient that I already have one!!
Edited by richminiturbo. on 17th Mar, 2009. |
17th Mar, 2009 at 10:05:41am
Its hooks around on its self, so it needs cutting and re welding at 90 Deg, dont know what diameter buts really close the original down pipe. However fitting it will make taking the exhaust alot easier as the bolts are to the side. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
17th Mar, 2009 at 12:12:49pm
my gt17 runs 18psi quite easily! awesome turbo! "Cars are a lifetime of pain" |
17th Mar, 2009 at 06:22:55pm
yep i d agree with stef , i noticed a massive surge of power accidentally turning it from 12 to 17 aT AVON ..as stock the compressor is fitted to several vehicles running around 20 psi as well. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Mar, 2009 at 06:39:57pm
what rpm does the gt17 start to spool up?
My build thread..
