| Home > General Chat > Anyone use nikkai usb serial converter from maplins? | |||||||
![]() 673 Posts Member #: 1395 Post Whore chepstow |
17th Mar, 2009 at 11:56:47am
I cant seem to install mine. It says its plug and play and doesn't need the disk. I cant get it to install with the disk in or out :(
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
17th Mar, 2009 at 12:04:55pm
try updating it via windows update? It will ask you to check the internet for drivers, worked for mine. (although not from maplin) "Cars are a lifetime of pain" |
1050 Posts Member #: 764 Post Whore Staffordshire |
17th Mar, 2009 at 12:13:41pm
i think t2clubby has one of these, he had some issues with it, but did get it working. |
17th Mar, 2009 at 12:53:15pm
having faffed around with usb convertors i tried a pcmia-232 convertor worked a treat, was ony a fiver off ebay too! would never bother with the usb ones again. On 28th Aug, 2011 Kean said:
17th Mar, 2009 at 12:55:51pm
I use the PCMCIA one's at work too for out PAT testing devices. The USB one's are nothing but trouble. If something is worth doing, it's worth doing half of. |
17th Mar, 2009 at 01:08:35pm
I have also heard of problems with the Maplins one, so I bought cheap and cheerful off eBay - four in total because of all the Megasquirt and TechEdge stuff I'm working with.
17th Mar, 2009 at 01:15:29pm
This thing was £15...
17th Mar, 2009 at 01:34:34pm
The issue with them generally is the drivers and the way you have to install them (in many cases they have to be installed before you plug the thing in, not after....)
17th Mar, 2009 at 06:10:48pm
I gave up with it in the end. Took the desktop outside. Car is now running |
17th Mar, 2009 at 10:14:34pm
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
17th Mar, 2009 at 11:05:28pm
i had trouble installing mine on my laptop (maplin item with windows vista). dont think the drivers that come with it work on vista. had to download some special drivers off the net.
18th Mar, 2009 at 10:47:37pm
Keyspan US-19HS or something like that works well
19th Mar, 2009 at 10:16:46am
On 17th Mar, 2009 Monkeh said:
i had trouble installing mine on my laptop (maplin item with windows vista). dont think the drivers that come with it work on vista. had to download some special drivers off the net. i can send the installer to you if you like, might be worth a shot. yes please that would be good. Will it send in an email? |
19th Mar, 2009 at 06:10:28pm
http://lib.store.yahoo.net/lib/cooldrives/...al-adapters.zip
