Home > Technical Chat > Rear Engined Mini - A-Series - Gathering thoughts and Info
Chaps, im off ill at the moment and bored out my tree! and with the tangerine nearing its completion my thoughts have turned to my next project. I have always fancied a rwd mini, but not one of these fancy bike engine types, a proper mini engined mini. Ive done a bit of searching on the net and ive seen someones pics on here with a front subframe in the back but i cant for the life of me find the thread! The main reason im thinking rear engine is for some drag strip action! Nice back end grip seems to be the way foward! Does anyone have any decent pics of a rear engined mini? These thoughts are in there early stages at the moment and im just trying to gather more info on the subject.
Babble over
Mike
Plenty here mate
http://www.miniclubzagreb.hr/Forum/viewtop...bca787fe19aa602
Paul
Its Carls Polish Lover!
or if your not croation
http://www.tranexp.com:2000/InterTran?type...from=cro&to=eng
still gibberish mind
Edited by wolfie on 1st Apr, 2009.
Nice find btw.
Pics no workie, or is it the web book im using?
Not an A series but you get the idea:
http://www.16vminiclub.com/forums/viewtopic.php?t=5727
Dahah, nice one, metro subframe! Keep em coming chaps.
codd_coupe
Member #: 1772
Leicestersheershire
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=238690
You can copy how the GTMs are done, you can get most of the non mini bits too.
Tim Rowe
"Is est totus perfectus per fumi quod speculum"
GTM Coupe Turbo
you got any good sites?
not to worry found one http://www.gtmdrivers.com/forum/
Hmm nice little gearchange solution
codd_coupe
Member #: 1772
Leicestersheershire
That is what I am running on mine. Alan on the GTM forum sells them. All you need to do is turn the plate through 180 degrees, so that the gate for reverse is in the right place. Oh, and you'd need to redrill the reverse light switch too.
Tim Rowe
GTM Coupe Turbo
reverse lights. what are they lol
if you do go down this route, my mate as an A+ gearcasing which has been converted to have the gear change come through the front of the box. He's done it the same way as Carl's twinny. He's not using it now as he's gone for twin bike engine instead
Only trouble with that though is no reverse.
paul
Hmm i was looking at some casings i had and thought that the reverse would have to be removed!
reverse is an easy fix with an eletriic motor i guess,
what about a handbrake?
line lock the brakes i suppose
does the clutch master need a booster of some kind?
or will it move fluid the extra length?
cannot line lock the brakes. its needs to be a mechanical locking system to pass the MOT.
that is if you are going road legal i guess.
codd_coupe
Member #: 1772
Leicestersheershire
You have either got the option of drums on the rear, with a combination of front and rear drums, OR, I've modified my hubs (as have others) to take another disk brake. I'm using MGF as the handbrake is adjustable, but there are others that can be fitted. I think there has been X1/9s used.
Tim Rowe
GTM Coupe Turbo
come on think about it, the fluid will not change size.
as mini13 says, it will not make a difference it will just mean that the system will hold more fluid as it has longer lines.
i was just testing you joe.....lol
codd_coupe
Member #: 1772
Leicestersheershire
All you really need to do is use copper pipe for the majority of the run, rather than hose, or it won't have a decent feel. Other than that it is identical to the usual mini set up.
Tim Rowe
GTM Coupe Turbo
