| Home > Help Needed / General Tech Chat > cutting bolts | |||||||
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
18th Apr, 2009 at 04:34:32pm
1310cc TWINK - T Conversion |
1050 Posts Member #: 764 Post Whore Staffordshire |
18th Apr, 2009 at 04:40:34pm
i always put a nut on beforehand then remove it after cutting it to clean the threads. |
18th Apr, 2009 at 04:43:22pm
I used to put a nut on before cutting as Anton said but now I simply cut parrellel to a thread. Once you keep the hacksaw perpendicular to the bolt face the threads will be fine On 12th Nov, 2009 Paul S said:
Gary's description is best |
18th Apr, 2009 at 05:11:38pm
yep, as above pop a nut on,
18th Apr, 2009 at 07:07:42pm
Yeah, keep the saw in the same direction of the thread and putting a nut on cleans the threads up when you remove it.
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
18th Apr, 2009 at 09:26:06pm
i always pop a nut on to help clean the threads, then clean the end up on a grinding wheel very quickly On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
18th Apr, 2009 at 09:35:43pm
Lathe Isambard Kingdom Brunel said:
18th Apr, 2009 at 09:47:32pm
File or grind a chamfer on the end once its cut helps too On 19th Jan, 2010 wil_h said:
18th Apr, 2009 at 10:18:52pm
Put your comments into practice this afternoon and it helped a lot. Many thanks. 1310cc TWINK - T Conversion |
18th Apr, 2009 at 11:19:44pm
practice!
Own the day
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
21st Apr, 2009 at 04:45:19pm
I always go for a finer hacksaw blade (32tpi), if i've got a few to cut i usually go for a new blade. Go for a decent branded blade. Nothing worse than going at tough bolts with a blunt blade. Make sure your saw is tight and the blade mounted nice and square.
21st Apr, 2009 at 06:02:27pm
if its a hex head, clampthe head and the bolt flats that you have wound down the head for extra support "Turbo's make torque, and torque makes fun"
21st Apr, 2009 at 06:28:49pm
If you are gripping it by the thread in a vice...use a softer material like wood or ally on the jaws On 19th Jan, 2010 wil_h said:
21st Apr, 2009 at 06:38:11pm
Unless its the bit your throwing away lol
On 21st Apr, 2009 Jason G said:
If you are gripping it by the thread in a vice...use a softer material like wood or ally on the jaws 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd Apr, 2009 at 09:59:27am
On 21st Apr, 2009 MikeRace said:
Unless its the bit your throwing away lol On 21st Apr, 2009 Jason G said: If you are gripping it by the thread in a vice...use a softer material like wood or ally on the jaws Exactly. I always find that clamping the head lets the bolt twist when cutting. You can clamp the piece of thread that you want to remove as tight as you wish. In the 13's at last!.. Just |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
22nd Apr, 2009 at 10:18:32am
like the others say i put the nut on first, then i move the nut to where i want the cut to be, and cut along the edge of the nut. job done, easy peasy |
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
22nd Apr, 2009 at 10:33:24am
As above I always put a nut on prior to cutting.
22nd Apr, 2009 at 10:37:03am
I usually use a thread file to clean up the threads after cutting. Team www.sheepspeed.com Racing
