| Home > Help Needed / General Tech Chat > when my mini comes onto boost it cuts out. either runs out of fuel or too much??? | |||||||
19 Posts Member #: 6070 Member |
11th May, 2009 at 01:22:10am
when u rev it and boost comes on it cuts out or dies out of rev. like it would when theres fuel running out. what might the rpoblem be. im using a holley 3-9psi regulator. it doesnt have vaccum on it for one and also using a na hif44 metro carb with turbo needle and jet..???? help na engine + turbo + boost = ya hewwww |
11th May, 2009 at 05:55:16am
it seem that you're not pressurise the float chamber correctly,or that your fuel pressure doesn't rise enoughly above boost.
11th May, 2009 at 06:27:53pm
How old is your fuel pump?
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
12th May, 2009 at 12:16:15pm
wheres the pic up in the fuel tank? if in rear could starve the car of fuel too 16V project underway |
12th May, 2009 at 01:32:34pm
As Fab said, your pressure regulator needs to be a rising rate unit that will increase fuel pressure with boost.
12th May, 2009 at 02:37:01pm
holy dejavu Batman http://www.turbominis.co.uk/forums/index.php?p=vt&tid=290009 On 17th Feb, 2009 Rob H said:
12th May, 2009 at 03:53:08pm
Had this very same problem and it turned out to be the part throtle lean off pipe had a hole in it.
Own the day
12th May, 2009 at 04:52:45pm
this carb doesn't have the part cruise lean trick |
