Home > Help Needed / General Tech Chat > mini jig/Rotisserie/spit
What ever there called
i know you can get them for the mk1 poss mk2/3 shells what about the mk4 onwards without the holes in them?
any pics about?
anyone got one
I think frost sell them which you roll the car with, is lisa mini that bad?
its fairly bad yes, problem i have is i cant weld upside down and the car needs a new boot floor so i cant have subfarmes in
Would this do you buddy?
http://www.frost.co.uk/item_Detail.asp?pro...roductName=Body Roller &catID=&frostCat=&frostSubCat=&subCatID=
or this maybe?
http://www.frost.co.uk/item_Detail.asp?pro...ctName=Standard Chassis Tilter&catID=&frostCat=&frostSubCat=&subCatID=
one on ebay too http://cgi.ebay.co.uk/car-bodyroller-jig-r...3A1%7C294%3A200
Neil, lay two lumps of 4x2 [jim and dave] on the floor, heave car on its side, and it will rest on the cill seam, then support the weight on the roof gutter once you find the balance point,
carl
Edited by fastcarl on 15th May, 2009.
chassis tilter is the sort of thing i am after as the other needs the subframes in
problem with the chassis tilter is it mounts on bumper mounts, the mini is to weak at these points
i might have a pop at making my own
i damaged a 1/4 panel last time i did that carl
I had thought about making one that pop's onto the front subframe towerbolt holes with the bonnet/grille of and on the top of the rear top shocker mounts and boot hinge bolt holes.
Oli
Member #: 1910
Wilts
Take a look at advantage998's build thread, might give you some ideas about a spit.
As his bolts to the front shock mounts at the front.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=251655
thimo
Member #: 710
Amsterdam, The Netherlands
For a Van it's probably easier as there's no rear bulkhead, but here are photo's and Dutch comments for my spit. Might help...
http://www.ferrenzo.nl/dagboek/15-03-2004.php
http://projects.ferrenzo.nl/
for all the hassle of it, you could cut the hole you need in the rear bulkhead for a spit and then weld it up again when your done?
we used a length of scaffold pole with some timber packers to secure to the shell and a couple of timber tressles. cheep and simple
your a mind reader Rob *wink*
Scruffy
Member #: 328
Seaford Rise, South Australia
Got one that bolts to the shock mounts on the front and the towers on the rear.
On 5th Sep, 2011 Vegard said:
littlejem59
Member #: 2544
Biddulph, Stoke on Trent
Try this, easy and fairly cheap to make yourself
http://minimikebc.tripod.com/rotiss3.html
any pics about?
anyone got one
It's not the age that makes me creak it's the mileage
Mini_Andy
Member #: 432
can you not just roll the shell onto a couple of matresses?
t3gav
Member #: 229
Gavin@minispares.com
kent
Some good pics here http://www.theminiforum.co.uk/forums/index...16&hl=spit&st=0
Turbo Tel
Member #: 588
Delaware, USA
Thats basically what I did, as long as the bodyshell is completely stripped, subframes glass and all, and you put the foam somewhere where its supported (i.e not in the middle of a panel) its fine, I did not have any problems with denting the sides..
Terry
