| Home > General Chat > Welding in a T Shirt | |||||||
13th Jun, 2009 at 06:57:01pm
I normally insist on wearing a boiler suite whilst welding however recently it's just been too hot, so I thought I'd have a go at welding in a T Shirt like the Americans do on the telly. Anyway the first time I tried it I came away with slightly sun burnt arms, which is definitely not a good thing. So today I put some SPF 50 sun block on, no skin cancers for me thank you, however it seems the dust from grinding sticks to sunblock quite well so now I look like I've been living in a coal mine. Isambard Kingdom Brunel said:
13th Jun, 2009 at 07:01:56pm
I was welding in a t-shirt the other day aswell. Its a wierd little patch of sunburn that i couldnt understand the next day, The little bit of exposed skin between in the gauntlet and the t-shirt that gets sunburnt is a hard one to work out if your not thinking straight!
13th Jun, 2009 at 07:09:57pm
My best one was a few years ago, having to weld in a totally inaccessible area (different car) where I couldn't wear the mask/visor at all as it fouled on all the surrounding bits.... so I did what I'd seen the coded welders at work do before for tricky bits and just used the little rectagular coloured glass in front of my eyes.
13th Jun, 2009 at 08:32:43pm
13th Jun, 2009 at 09:54:37pm
Did the same a few times. Ended up with the skin peeling off at my elbow joint and around there.
13th Jun, 2009 at 10:10:27pm
When I first started with my TIG I burned my arms badly, I thought I was just playing but must have been at it for a while, I now wear long sleeves and gloves!
13th Jun, 2009 at 10:14:52pm
I think I'll have to pop over to Matalan and get some cheap long sleeve T-shirts for summer welding.
13th Jun, 2009 at 10:25:25pm
Welders sun tan, i have had my fair share of that. Annoying part is you know that it happens , yet we still wear a T shirt. And, you dont usualy find out till the following morning when its flaming, lol On 26th Oct, 2004 TurboDave16v said:
13th Jun, 2009 at 10:28:04pm
On 13th Jun, 2009 Bat said:
Hi, I always weld in a tee shirt, that's why all my tee shirts look like teabags
Cheers, Gavin :) You need to turn the wire speed down. Shielding gas helps too
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
13th Jun, 2009 at 11:02:16pm
living where i do i generally weld in shorts and flip flops BUT i do where a long sleeved top(overalls cut in half at the waist) as i have way to many scars from the spatter.(Nasty gasless MIG) Edited by miniboo on 13th Jun, 2009. |
14th Jun, 2009 at 12:16:18am
I burned my face soo bad once i couldnt put my glasses on for 3 full days and had to stay off work (due to my face swelling up), 4th day started peeling, and 5th day looked like a leper, just coughing would cause big flakes to fall off....
14th Jun, 2009 at 07:54:49am
When I was In night school getting my welding cert. I remember coming home one night feeling rather flushed taught I just have a wash and go to bed, I did so woke up next morning late for work so no shave etc, when I got into work Sam on the desk nearly had a hart attack when I walked in. Turned out I had 2nd degree on 95% of my face and my lips where blue. Ended up in the burns unit of local hospital for a week and two skin grafts really not nice. Now I wont even tack with out a shield just not worth it. Edited by PaulH on 14th Jun, 2009. On 17th Feb, 2009 Rob H said:
15th Jun, 2009 at 02:52:42pm
Welding in a T Shirt.................Is a bad idea Own the day
![]() 2102 Posts Member #: 432 Post Whore Swindon |
15th Jun, 2009 at 03:08:27pm
95% of the time i weld in a T-shirt, jeans, builders gloves and a face mask.
15th Jun, 2009 at 03:13:20pm
Been there before, you think youll just be tacking something up and bam you end up with the old flakey head!
On 14th Jun, 2009 mini13 said:
I burned my face soo bad once i couldnt put my glasses on for 3 full days and had to stay off work (due to my face swelling up), 4th day started peeling, and 5th day looked like a leper, just coughing would cause big flakes to fall off.... never again!! also for about 5 years afterwards i would burn really easy in the sun. ialso tigs seem worse for causing burn, ithink because there is less smoke? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
15th Jun, 2009 at 10:01:35pm
bloody large amount of UV.. (on a positive note: it is very anti viral..the continuous welder will be the last guy on the planet when the mexican flu goes bezerk :)) ) especialy when welding TIG.
16th Jun, 2009 at 11:58:43am
But the Ozone produced can damage yoyr lungs Own the day
