Home > Technical Chat > suspected pin hole in oil pick up pipe
nogin
Member #: 487
westbury, wiltshire
how can i test to see if i have a hole in the oil pick up pipe
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
If its not in the car replace it, theyre cheap enough.
If its in the car you cant test it really
Paul
I've got several holes in mne. Helps with picking up the oil apparently *wink*
nogin
Member #: 487
westbury, wiltshire
*wink* not if its above the oil line
i also make things
Hi
Put more oil in. I'm not recommending you go hairing round the country with 2 gallons of oil in, but you should be able to prove a point.
