| Home > Technical Chat > Small turbo | |||||||
157 Posts Member #: 6496 Advanced Member Somerset |
4th Aug, 2009 at 02:07:08pm
Forgive me if this has been posted before, but I have run a search and didn't find the answers I was looking for.
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
4th Aug, 2009 at 02:09:18pm
for a 1460 you'll get away with something fairly large.
4th Aug, 2009 at 02:19:52pm
Yea that's the one! It's an animal (excuse the pun).
4th Aug, 2009 at 02:23:32pm
Turbo Tel used a GT1548 on his 1293. As far as I remember, he was running 10PSI boost. He has some relevant stuff which would be worth reading. I think his max boost occured alot later than you are looking for though. 1500RPM does seem very low, I've never seen anybody achieve maximum boost near that before.
Gary's description is best |
4th Aug, 2009 at 06:55:29pm
There is a nice IHI RHF4 turbo in the for sale section that would be ideal for this On 26th Oct, 2004 TurboDave16v said:
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
5th Aug, 2009 at 02:08:40pm
Sounds like a job for a bini blower, if you ask me. Bugger off, I'm getting there. |
13th May, 2010 at 07:14:02pm
Dragging up an old post here, but what cam would be ideal for this application? bear in mind the motor won't be going over 6,000 rpm and I'd be after the widest torque curve possible.
13th May, 2010 at 07:40:47pm
I know the t2 5 turbo si spooling at almost past idling,
13th May, 2010 at 07:47:10pm
Ok, how about full boost about 2,000 rpms? On 9th Feb, 2010 joeybaby83 said:
13th May, 2010 at 07:51:58pm
On 13th May, 2010 fab said:
Gussing about turbo the audi s4 biturbo have 2700 cc and one turbo on each bank, making one turbo for 1350cc and it'll give full boost at 1800 rpm, then right up to 6500 rpm with a flow at about 140 bhp by turbo..; fabrice and uses these by kkk... K03-1870EXA/4.82 AUDI A6 TDI 1997 225 2.7/V6 P K03 5303-988-0016 078 145 703L AUDI ALLROAD 1997 izquierdo 225 2.7/V6 P K03 5303-988-0016 078 145 703L AUDI S4 1997 izquierdo 260 2.7/V6 P K03 5303-988-0016 078 145 701H cam wise id use the softest emissions cam you can find in the piper or kent book. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
123 Posts Member #: 1234 Advanced Member Chester |
14th May, 2010 at 08:01:12pm
I know a man with a brand new T2 (0.35 AR) if you fancy it... |
520 Posts Member #: 2093 Post Whore Grenoble, France |
17th May, 2010 at 06:57:37am
I don't think you can get full boost at 1500 on such an old designed engine head. Even on modern petrol engines it's quite hard. Combustion is not very stable at that RPM, not to mention the oil pressure that could be too low to properly lubricate crank bearings.
Edited by alpa on 17th May, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
17th May, 2010 at 06:58:19pm
Fit a supercharger. 9.85 @ 145mph
