| Home > A-Series EFI / Injection > Cam phase sensor | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
16th Oct, 2009 at 06:07:01am
Okay, I don't know if I'm typing in the wrong thing or what, but I'm having the damndest time finding a good build thread for the cam sensor for the sequential injection. Any help anyone?
16th Oct, 2009 at 07:18:15am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=228314
16th Oct, 2009 at 07:43:36am
Well linked by Rob....
16th Oct, 2009 at 08:02:58am
Other brand cat food tins can be used if you can't get them in the states. On 11th Feb, 2015 robert said:
16th Oct, 2009 at 09:12:52am
I'm about to embark on Version II of mine. It's going to be shorter and more compact, but still use the same sensor.
16th Oct, 2009 at 10:02:16am
You could also do it like this:
16th Oct, 2009 at 10:10:12am
On 16th Oct, 2009 Jimster said:
You could also do it like this: That is a better loction and avoids using the dizzy drive. It looks like VR sensor, so I assume it is using a toothed wheel at the back of the cam sprocket? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
16th Oct, 2009 at 10:15:34am
Neat, but if it is VR, you need to add some more circuitry to the MS2 (or another of Jean's boards) to accept a second VR input. Schrödinger's cat - so which one am I ??? |
16th Oct, 2009 at 10:18:40am
I like that. If something is worth doing, it's worth doing half of. |
16th Oct, 2009 at 10:46:11am
So do I.
16th Oct, 2009 at 10:48:49am
I've not seen the engine internally, I'm just wiring it up, so don't know whats inside, although I guess it's a toothed wheel with 1 tooth missing. It's running on a Omex ECU Team www.sheepspeed.com Racing
16th Oct, 2009 at 10:52:12am
If you usethe right type if sensor IE Vauxhaul, you can have either Hall or VR in the same packaging On 26th Oct, 2004 TurboDave16v said:
16th Oct, 2009 at 10:56:24am
On 16th Oct, 2009 Paul S said:
So do I. Just need to make a one tooth wheel to fit to the back of the cam sprocket. Does it need to be a tooth? It could be a disc with a hole, that would be easier. bolted along with the screws on a decent vernier gear perhaps On 26th Oct, 2004 TurboDave16v said:
16th Oct, 2009 at 11:07:27am
Disc with a hole would be OK software wise, as long as the ECU sees a change of state every two revs.
16th Oct, 2009 at 11:54:04am
On 16th Oct, 2009 Sprocket said:
If you usethe right type if sensor IE Vauxhaul, you can have either Hall or VR in the same packaging I wasn't aware of that but indeed some are.... The one in Jimster's picture is 99% certain to be VR as it only has a two pin connector (so far as I can judge from the size of it in the photo) but many of the Vauxhall ones have three pins which means Hall. But I wonder if they are 12V Hall or 5V Hall - not that it matters from an CPU safety issue with the MS design, but still need to know what voltage to supply them with. Schrödinger's cat - so which one am I ??? |
16th Oct, 2009 at 12:35:39pm
Well, there are no screws on the back of my vernier duplex.
16th Oct, 2009 at 12:57:07pm
As far as I was aware hall sensors used on ECU systems in vehicles are 5v much the same as the TPS
16th Oct, 2009 at 01:03:48pm
The sensor that I use is a 12v unit, but goes through an Opto-isolator on the ECU board.
16th Oct, 2009 at 01:05:07pm
the hall sensors I use are 5 - 15v ideal! Team www.sheepspeed.com Racing
16th Oct, 2009 at 01:12:58pm
The sensor that I use is a 12v unit, but goes through an Opto-isolator on the ECU board. That's what I thought from when you first chose it but I've just looked at the datasheet and it's actually 4.5v - 24V (so 12V would be best but could probably work on 5V) http://www.bbautomacao.com/home_hall_effec...r_cyhme301.html On 16th Oct, 2009 Paul S said:
Saves having to bring 5v out of the ECU. You already have the 5V feed from the ECU to the TPS, IAT and MAT - that's one of the reasons I chose the opto-switch that I could easily run at 5V to keep the wiring simple :):):) Schrödinger's cat - so which one am I ??? |
16th Oct, 2009 at 01:44:42pm
Very true.
16th Oct, 2009 at 01:58:04pm
Very true. I think that we had the same discussion last year. I'm certainly going to try and lose the dizzy body method if I can. Agreed it would be neater long term to have a better solution than a cut down dizzy, and hence more clearance and less moving parts. In my case I'm not too worried at the moment as I've gone for the clubman flip front (so plenty of room for the cut down dizzy and a front mounted radiator) and I'm STILL removing rust and welding new bits into the shell so it will be a while before I get to your 1000 mile test.... Schrödinger's cat - so which one am I ??? |
17th Oct, 2009 at 04:23:53am
Let me say three things. First: Holy hell, I didn't think this thread would go from 1 to 21 posts in a day, I was just looking for the build link... Second: How's the dizzy done exactly? Looks to me like you're utilizing two new plates attached to the dizzy, one for mounting the optical sensor maybe...? And the second for closing it, obviously rotating on the spindle and passing over the op sensor to send the signal to ms. And third, has anyone looked into the cam sprocket sensor with any fervor? Doesn't look like it would be too hard to put a missing tooth wheel in there just like on the crank, only this one would obviously run a cam speed rather than crank speed. |
17th Oct, 2009 at 04:26:29am
That's something that would probably be easier to do engine out though I'm thinking. do able engine in, but it's a tight space and you'd have to get the clearances right. What's the benefits of using a hall sensor over optical? Just more common or is there more advantages than that?
17th Oct, 2009 at 08:30:37am
On 17th Oct, 2009 miniswordsman said:
How's the dizzy done exactly? Looks to me like you're utilizing two new plates attached to the dizzy, one for mounting the optical sensor maybe...? And the second for closing it, obviously rotating on the spindle and passing over the op sensor to send the signal to ms. Assuming you mean mine (as Paul's thread is quite detailed and I only did a photo), yes - dizzy machined right down to it's base (which is conical) and a new basepalte machined to fit neatly inside the conical bit but be flat on the surface. held in with epoxy and four small screws from behind. Drilled/tapped to mount the opto switch. On the shaft, I machined the rectangular plate (that carries the weights) right back to a circle to act as a locating collar and machined a disk with a boss on the back to land on that collar, cut the shaft to length and threaded it for the retaining nut. Then cut a slot in the disk to operate the switch. The optoswitch has seperate connections for the LED part and the phototransistor so I just calculated the correct value of resistor to operate the LED at 5V (I prefer to use 5V) and it's inside the yellow sleeve. On 17th Oct, 2009 miniswordsman said:
has anyone looked into the cam sprocket sensor with any fervor? Doesn't look like it would be too hard to put a missing tooth wheel in there just like on the crank, only this one would obviously run a cam speed rather than crank speed. I think you started us thinking yesterday for the Megasquirt... the issue will be selecting a suitable hall sensor (as opposed to the more normal VR). I wouldn't advise it for your first build - it will be tricky getting clearances right and you would have to choose the position (relative to TDC) carefully because it will be inaccessible and non-adjustable. The dizzy version, whether Hall or optical, is easy to access and adjust. Schrödinger's cat - so which one am I ??? |
