Home > Help Needed / General Tech Chat > MJ vacum - dump valve pipe + map ?
Am i ok to put a T peice from the inlet manifold to feed both megajolt and the dumpvalve as ive only got one outlet or does the MJ need a separate feed.
Rick
Edited by cossierick on 4th Nov, 2009.
dump valve / waste gate / boost gauge i wouldnt be too fussed if 2 was T'd off but with mj id (personaly) have mj separate at least
I'd always run the dump valve off it's own hose, boost gauge and map sensor I'd have thought will be fine togeher.
Kean
Member #: 341
aka T2clubby
South Staffs
As Jim said, keep the dump seperate, T the gauge and megajolt together.
Well the boost gauge works through the stack dash so has an electronic sensor tapped into where the servo pipe goes.
I also tapped a pipe in the side of the inlet for the mj but completely forgot about the dump valve.
Would the vacume pipe work on the carb where the dizzy used to go?
Rick
Also gents while im on this, am hopully firing it up next week so has anyone got a map for or close to my engine spec?
1293
15cc omegas
266 cam
1.5 rockers
30/36 head
7.5:1 comp
Rick
Rick
no the vac advance port gives no vacuum at idle
edit : http://www.turbominis.co.uk/forums/index.php?p=vt&tid=266421
edit2: i believe the part throttle lean off pipe on the front of the carb can be through drilled though, i may be talking trash too*happy*
Edited by Brett on 4th Nov, 2009.
MarkGTT
Member #: 1194
Shropshire.
i 'T' my jolt and dv.. *oh well*
Edited by MarkGTT on 4th Nov, 2009.
On 4th Nov, 2009 MarkGTT said:
i 'T' my jolt and dv.. :-
And i gather yours is fine mark, no probs on the rr day.
Rick
MarkGTT
Member #: 1194
Shropshire.
yep its been fine Rick, ive seen no probs at all.
Thanks brett.
Rick
evolotion
Member #: 83
Glasgow, Scotland
its fine but on principle i always keep any ecu map sensors to there own feed to the manifold, if your megajolt (spark only obviously) and that hose fails you will loose your boost retard and hole a piston, having it t'd adds 4 un-necesary joints in the pipe and an un-necesarly legnth of pipe any of which could fail.
if you only have 2 vacuum sources, 1 fo the megajolt, one for everything else. on injected cars i like to also give the regulator its own vacuum.
Denis O'Brien.
Ok denis thanks,
ive only got one vacum point from the manifold so i supose the options are T into it and hope for the best or remove the manifold and drill and tap another port.
rick
MarkGTT
Member #: 1194
Shropshire.
Denis - good ponit.. sounds allot safer to run a direct feed to the jolt.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Mark.
I'm running mine T'd just as yours is but from what Denis has said, I'm gonna drill/tap another port this weekend and put the DV on one port and Megasquirt+Boost Controller+Gauge on a separate take-off.
Good point Denis.
Richard.
MarkGTT
Member #: 1194
Shropshire.
yep, i wont be far behind!
Carl S
Member #: 1761
Stalker
Rick
Just adding to this, it depends on the carb Brett. My HS4 does show vacuum with the butterfly shut, but they are not all the same.
i was sort of generalising towards the hif carbs i haven't used a HS4 since on my 998 years back *happy*
tadge44
Member #: 2500
Buckinghamshire
Part throttle lean off connection on the HIF, drilled through, gives me readings that I rely on on the boost guage.
Not everyone agrees.
