Home > Show Us Yours! > Nice little win on ebay :0)
kstead
Member #: 1126
peterborough
won these on ebay, plan to use the 1/4 unf round the gearbox and the 5/16 just generally. All aircraft so should be decent quality.
Not bad for a fiver eh!
I use them for manifold bolts, very very hard stainless
Paul
kstead
Member #: 1126
peterborough
I love the high quality look of them, any ideas who would supply them, measured up and some of the 1/4 may be a tad short. they're 1.125 long
Nice find, but have you got the 12 point sockets to drive them?
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Ive got a shitload of them, I think they awesome. Do they have the nylon insert?
Build Thread Click Here
kstead
Member #: 1126
peterborough
Yeah got stuff to drive them but not being able to use an open ended might slow things down a bit?
What do the inserts do?
Got a mate who used to do a lot of lock wiring on harriers when he was in the raf so he's gonna teach me the proper way to do it. Should look awsome all lock wired :0)
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Some of the ones I have have a slot going along the threaded bit thats filled with nylon. It does the same job as a nyloc nut.
kstead
Member #: 1126
peterborough
No not got that on them, so clever these aircraft chaps!!!
they look nice. i can't see you need any thing different from standard bolts in the gearbox IMO *wink* just wanted to tell you.
This seems to be the only source of these bolts in the UK:
[url]http://www.brspecialtuning.co.uk/Consumables.htm#NAS bolts[/url]
Not sure how you work out the part number and if they are specifically 12 point.
Edited by Paul S on 21st Nov, 2009.
madcatminis
Member #: 5327
Dudley, West mids
I work at an aerospace company and had a few spare bolts left over from a part I was making. The bolts I erm (liberated) lol fit straight into the carb holding the bottom plate on. Pitty its a different thread to the top ones though.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Good stuff for a fiver.
As Paul says, I too use them as manifold bolts - much easier to get a 12 point thin wall snap-on ratchet ring over.
Got about 100 of these, from 1/4 to 7/16. All from old broken Rolls Royce marine turbine engines !
Yours might even be the better 1/4 and 5/16 UNFJ with the rolled threads. Very strong. If you got the 12 points squish nuts, they're silver plated to prevent corrosion.
If you use regular stainless nuts, you need to lub them up with clean engine oil as they can sometimes suffer from cold-welding where the threads pick up and seize as you're tightening. Best bet is to tighten really slowly.
Loadsa uses.
Richard.
I've used some of these,
they really are very nice!
great for hot places.
pickmeup
Member #: 1200
one of the benefits of working in aerospace is checking whats 'dropped' on the floor :) got a few of these but need to re-stock soon
