Home > A-Series EFI / Injection > Fuel Pump Options for Traveler
tmsmini
Member #: 7637
Fremont California
What have people done to provide an intank solution and return lines on a LWB Mini? Anyone modified a Rover pump to fit?
This site has an interesting solution:
http://www.stallard-engineering.co.uk/stor...he_fuelling.htm
I was looking at some solutions here in the US for converting older cars to EFI, but most are really large and I am concerned with routing around the subframe. The side mounted option in the link seems a good one except for exposure.
Terry
I am guessing this should actually be in "beginner's tech" where I had originally found this post:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=312734
Edited by tmsmini on 8th Jan, 2010.
thats a nice solution, I like it!
most people just tee peice in an external pump
I was going to ask about this to see what people did. But in the end I thought that 'T'ing into the low pressure side of the pump is the best idea.
For two reasons:
1) it's cheap, easy and doesn't involve removing the tank
2) The original pipe from the tank is maybe a bit too small, if you 'T' into the low pressure side of the pump it effectively increases the flow to the pump.
The surge on these tanks is terrible. Speak to Brumski over on EFI Minis, lol, he suffered from fuel starvation over the Mountain passes on the Italian Job, yet there was loads of fuel still in the tank.
Lift pump, swirl pot and an external high pressure pump is a better option
The internal pump modification is real neat though
Edited by Sprocket on 8th Jan, 2010.
tomf
Member #: 1746
Kent
I had exactly the same problems Sprocket mentioned, in the end i fitted a swirl pot, was the only way i could stop fuel starvation, i even tried fitting an internal pump, but that didnt solve my problems...
Is the fuel starvation a problem for carb'd cars? Because of the float chamber you may negate any issues.
tomf
Member #: 1746
Kent
For me the fuel starvation issue with because i had converted to k-series so fuel injection, i never ran the car with a carb engine so couldnt tell you if there was any issues there.
tmsmini
Member #: 7637
Fremont California
Some additional links for future reference:
Link to Fuel Feed Module from WEBCON mentioned in the EFI forum:
http://www.webcon.co.uk/Downloads/PR/2008%...ed%20Module.pdf
Link to discussion on van/estate soultions with some pictures:
http://www.efiminis.olicentral.com/index.p...651&topic=434.0
That Webcon pump looks the business and the price is not scarey
Depth might be an issue perhaps
Edited by Sprocket on 12th Jan, 2010.
tmsmini
Member #: 7637
Fremont California
It was indicated that the WEBCON link had specs, but it is really an advertising piece. It would be nice to know the size.
And yes the price seems right...
Found the specs:
http://www.webcon.co.uk/Downloads/WFP096-1.pdf
Edited by tmsmini on 12th Jan, 2010.
Sandra
Member #: 8231
Hi all
I have fitted the Webcon pump into the original van/traveller/pick-up tank, using a box welded to the base. As yet it is untested in terms of surge. You might be interested in the pictures...
Sandra
Looks like a great rabbit catcher :)
OIther than that, those pumps look the dogs danglies :)
tmsmini
Member #: 7637
Fremont California
Thanks for the pictures, so what is the height of the fuel tank. I just ours out, but never measured it. The pump is 195 millimeters = 7.67716535 inches
Sandra
Member #: 8231
fuel tank on van-pickup-traveller is 16.5cm:)
What's tha tin Sandra? it seems to be mostly GRP, but I can't work it out.
Sandra
Member #: 8231
I had a 5cm tray welded to the bottom of the tank to accommodate the Webcon pump. The car is a mini Phoenix Pick-up as far as we know it was a prototype.
