Home > Help Needed / General Tech Chat > Will GT17 fit mirage manifolds with bulkhead cut and boxed?
alaskanow0
Member #: 8466
Mansfield
I'm new to the whole turbo thing, been running a Vmax charger kit, however I've come to my senses! I would like to achieve 150bhp+, but really don’t want a T3 setup due to the lag issue. I am seriously considering the mirage kit, with a T2 hybrid (T25 internals and compressor housing, but I keep reading how good and efficient the GT17 is.
My question is, can the GT17 be mounted to the mirage manifold if the bulkhead is cut and boxed? I really don’t mind the cutting and welding if it creates more space and clearance. Would I have to modify the fitting flange and make my own end plate and down pipes
Are there any other options out there, I know Mike Race as a GT17 on a modified the Metro T3 manifold, is this just as easy and efficient?
No, the GT1752 cannot be fitted with the Mirage manifold. The compressor fouls the block.
Bat tried it.
Paul, didn't you develope up with a manifold that alows a GT17 to be fitted without a bulkhead box?
The powers of search:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=213856
I think it can be done, although I never got around to building up a manifold to try it.
I plan to make one up for the 998 sometime soon.
Edited by Paul S on 3rd Mar, 2010.
