| Home > Show Us Yours! > German EFI turbomini | |||||||
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
5th Apr, 2010 at 12:52:31pm
15 Posts Member #: 8841 Member |
5th Apr, 2010 at 05:20:36pm
here is the energie |
5th Apr, 2010 at 05:27:41pm
i like the laptop stand, http://www.youtube.com/watch?v=TBM2NMdPo0o
Yes i moved to the darkside |
5th Apr, 2010 at 05:27:57pm
That looks like a nice setup. Too bad you're using a rip-off of the Megasquirt (kdfi).
5th Apr, 2010 at 05:54:31pm
Although it's obviously stolen, the Manual refers to MegaTune which means it can't run the siamese code ???
5th Apr, 2010 at 06:03:32pm
no i use not the siamese code but the kdfi is working with the siamesian injektions |
5th Apr, 2010 at 06:16:10pm
On 5th Apr, 2010 Rod S said:
Although it's obviously stolen, the Manual refers to MegaTune which means it can't run the siamese code ??? TBH Jean, for people like this I wouldn't be interested in their configuration. I understand your point Rod, but that's a bit harsh. If I had the option of an ECU with good local support then I would think hard about it. MS is OK in the english speaking world, but otherwise support is probably sparse. My concern is that he does not appear to be monitoring AFRs on inner and outer cylinders. My own trials with the standard MS/Extra code "worked" but I would not have risked a turbo on the engine with the lean outer cylinders. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=196778 Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
5th Apr, 2010 at 06:28:18pm
On 5th Apr, 2010 Paul S said:
I understand your point Rod, but that's a bit harsh. I'm not so sure Paul.... look at what happened when Patrick wrote a bit of additional code for traction control. The key people at Megasquirt roundly condemmed him and deleted his code from the forum. And he was making no attempt to sell it, he was just trying to help others. Once people take the code and sell it (whether it be Jean's or an early version) my view changes. I really don't understand the "licencing" issues but clearly something is wrong here. Schrödinger's cat - so which one am I ??? |
5th Apr, 2010 at 06:31:02pm
Surely the issue is with K-data?
5th Apr, 2010 at 06:39:23pm
I'm not sure it's too harsh either. The problem is that the kdfi people and anyone else who does the same are mainly leeching off the MS project and racking in the money using other people's work without contributing anything.
