Home > Help Needed / General Tech Chat > head gasket selection
minimonster
Member #: 7614
Malaysia
just want to ask you all..
what is the best gasket for modified mini?
my engine spec is 1275cc bored to 0.20,ported head,stock head stud..
just wondering if the standard copper gasket can withstand the temperature of the engine and in Malaysia...
so can u guys suggest a better head gasket than the original copper?i dont want the head gasket to blown up..
so thinking about BK450,AF460,the competition head gasket or the turbo head gasket..
any suggestion?
http://www.minimonstermotorsport.blogspot.com/
http://www.retrosyndicate.freeforums.org/index.php
BK450 would be my gasket of choice.
MarkGTT
Member #: 1194
Shropshire.
Yep BK450 for me too.
Failing that the AF470, pretty much the same just has an additional O-ring for the oil-feed.
minimonster
Member #: 7614
Malaysia
can u please show me any picture of the bk450 gasket?i already bought one but my friend said its not the geniune gasket..so it makes me a lil bit confused..
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
A460 is also a very good head gasket. anyway both bk450 / AF460 will do the job
There are pictures of the relevant parts (of an AF470) in this thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=298689
The BK450 is marked the same apart from obviously the number. The two are otherwise identical apart from the O ring around the oil hole that John has already mentioned.
