Home > General Chat > MED Heavy Duty Verto Clutch
Brocky
Member #: 224
Katy TEXAS
Alright Guys,
Does anyone know how many curly wurlys these are good for?
I does say heavy duty turbo...
http://www.med-engineering.co.uk/product_d...77&vlang_id=620
or does anyone know how to go about lightening a standard verto flywheel ?
Brocky
correct me if im wrong but looking at it it is just a turbo clutch on an med light verto flywheel
Is that the MED 'not quite as' light verto flywheel?
I'm sure that MED would be best to ask about estimated curly limit.
yep they've added a fair bit to it!
Yeh, I bought my flywheel only a few weeks ago and compared it to a standard flywheel. Allthough it is lighter than the standard flywheel, its still heavier than the pre verto ultralight, but, I am not phased by it, as for a road car, more weight is probibly better. More mass is certainly better at absorbing the heat from the clutch.
Edited by Sprocket on 20th Jul, 2010.
Ive got the minispares one on my car. Not quite as light, and ive only done 200miles and on it so i cant tell you how it is
strangely the MED billet one is cheaper than the Minispares one.
Do they still sell two types or os this the new, less likely to fall apart version?
it looks like this is the "redesigned" version
I just hope that the extra meat isn't needed!
NickG
Member #: 7912
Australia oi oi oi!
i just bought one. ill let you know how i go.
should be in about 3 or 4 weeks time.
Brocky
Member #: 224
Katy TEXAS
Guys,
Got reply from MED,
The uprated clutch cover is 20% up on the original turbo unit.
I have the 30% uprated cover from techniclutch and that is holding well at 11-12psi on a well sorted 1310 which produces about 125 nannas.
I think I will just order the flywheel and use my cover.
Brocky
