Home > 998cc > Replacement +40thou 1098 hastings piston rings?
998turbomini25
Member #: 2276
sheffield / derby
Hi all
As some of you might have seen im now int the process of rebuilding my 1098 supercharged engine after a mere 300 ish miles after the thrusts had spun.
As i am replacing the block crank and bearings etc i figured i would replace the rings and completely starting a fresh,
I am running +40thou hypatec pistons with hastings rings that i got from minisport aus.
Does anyone know where i can get new rings from that fit these pistons? Other than getting some sent over from australia??
cheers Luke
Edited by 998turbomini25 on 25th Aug, 2010.
I would look at total Seal rings.
I was thinking of getting some total seal rings. I know Sprocket has used them, and maybe he has the answers below:
1 - what is a typical cost of a set?
2 - How do you go about getting the righ rings for your pistons?
We have total seal rings in the van. They cost about £105 delivered.
Have a read of this, all the info you need:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=355598
Looking at http://www.totalseal.com/SearchByApplication.aspx They only do large bore rings, so probably not an option for Luke. That said, they may be able to make a custom set for you.
Too pricy for me then, a set of new pistons is only a few quid more than that.
Speak to Minispares as they use Hastings rings for their mega pistons.
liszabailey
Member #: 9254
what type of hastings piston rings are you looking is there a size for it? maybe you can look for those parts in the US? what do you think?
It was £105 delivered to the supplier in york. There was then carridge on top of that, so closer to £115. Good rings, but not worth it when the pistons are so cheep.
Edited by apbellamy on 17th Dec, 2010.
good luck with the rebuild luke.
