Home > Technical Chat > Bulkhead Space
tonton
Member #: 9069
Dumbarton
Hi
Although I have the lower bulkhead mod done for the turbo, on the top half there is no hole that I have seen in other minis that lets the carb/plunem fit, (I bought the shell like this and I presume late minis didnt have the hole?)
Whats the best way to get round this ? Just cut a hole? How should I fill the hole afterwards?
If you have an adjustable top engine steady you may be able to tilt the engine far enough forward to give clearance ?
tonton
Member #: 9069
Dumbarton
Thanks, tried that, only have the bottom mounts on and with the starter motor hard against the front I still dont have space.
Hit it with a big hammer!
tonton
Member #: 9069
Dumbarton
If I cant figure it out thats exactly what I will be doing!
And if that doesnt work, use an even bigger hammer !!
I wouldnt tilt the engine forward. Oil will gather on top of the valve guides and be more prone to sneaking down and getting burnt ( and being smokey )
turbominivanman
Member #: 1504
Westbury, Wiltshire
Check out the pic I posted in this thread.
You could do something similar, but smaller if necessary.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=406209
Richard.
You dont have an engine steady fitted! the engine will always sit back a little without evn a standard one
i dont have the hole there, my engine is tilted forward ever so slightly and is solid mounted with some of carls adjustable rose bushed steadys there is about 10mm clearance
Edited by wolfie on 31st Jan, 2011.
