Home > General Chat > mounting intercoolers
OK - going to be working on this shortly and am putting a bit of thought to the mounts. I'm hoping to use an Audi TT cooler sited over the starter motor area.
Something that I recall reading last year related to mounting the cooler off the engine or body but I can't recall which way round was recommended. I suppose the thought of it mounted to the engine would be it moves with it, however by mounting it to ther body, it won't be (mounts) subjected to the vibration of the engine in the same way but the pipes will - the concern here being the unit has plastic tanks and mounting lugs.
I was following this thread but the photos are now missing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=294956
what are your thoughts??
cheers
Rob
All mine are mounted to the body, there is enough flex in the silicon joins to allow for engine movement.
On the TT2 I have the bottom attached to the subframe and the top to the engine, this means as the engine moves the IC does a bit too. I did this as I didn't want to stress the carbon plenum too much. There are no such worries with a HIF and big metal plenum.
Two choices really, either solid mount it to the engine or mount it to the body with some form of flexible mountings.
mine was mounted to the subframe and slam panel like an mpi rad
cheers guys - I'll take it from the comments it doesn't really matter then - i'll just make the brackets up best to suit the location
cheers
rob
haha, flexible mountings on the Sprint are zip-ties.
Look at most OEM installations, mounted just like radiators, the rubber hoses allow for engine movement.
you can't beat zip ties for a proper install!
yes mine is solid mounted to body as well, and I've left some joins in silicon bends for the engine movement.
Go take a picture right now matt to show us *tongue*
ok John
wait a min......, you nearly had me there!
Worth a try.
good try John!
