| Home > A-Series EFI / Injection > EFI 5-port turbo for sale in Norway | |||||||
9th Jun, 2011 at 07:42:36am
http://www.finn.no/finn/car/used/object?finnkode=28892343
9th Jun, 2011 at 07:59:18am
Looks nice enough but it also looks like it has crashed into Hudds mini spares ,lol |
9th Jun, 2011 at 08:14:29am
I think I remember seeing this in MiniWorld. If something is worth doing, it's worth doing half of. |
9th Jun, 2011 at 08:19:22am
Interesting injector setup.
9th Jun, 2011 at 08:21:21am
On 9th Jun, 2011 Rod S said:
Interesting injector setup. Does it say which ECU it's using ? (I can't read norwegian.....) It doesn't say anything. I guess the name of the ECU would be the same in both languages though
9th Jun, 2011 at 08:37:18am
On 9th Jun, 2011 Vegard said:
I guess the name of the ECU would be the same in both languages though True, but not being able to read the front page meant I couldn't figure out which link went to the detailed description (if there is one) - I tried a couple at random and just got what looked like how to pay on one and various loan/finance options on another, so I gave up :) (edit - spelling) Edited by Rod S on 9th Jun, 2011. Schrödinger's cat - so which one am I ??? |
9th Jun, 2011 at 09:44:05am
It was built by Brede Alnes of TS Racing.
9th Jun, 2011 at 09:45:50am
I knew it was in a magazine. I just got the wrong one. If something is worth doing, it's worth doing half of. |
9th Jun, 2011 at 09:50:37am
Good job you're not bitter Paul. On 11th Feb, 2015 robert said:
9th Jun, 2011 at 10:10:54am
On 9th Jun, 2011 Paul S said:
It was built by Brede Alnes of TS Racing. Featured in Minimag May or June 2007. Another one of those "it works so it must be good" setups. What interested me was the fact they have two injectors per runner and have gone to a lot of trouble to get them parallel to each other by widening the runner - they look like standard size injectors rather than the pencil ones your going to be using. Can't figure out if it's a flowrate issue (maybe high flow ones were more expensive than the cost of widening the manifold and using two low flow ones), or a staged system (but then why put them parallel to each other) or an attempt to aim them at the individual inlet valves and run a "standard" sequential system (ie, as if it was an 8 port). Strange. Schrödinger's cat - so which one am I ??? |
9th Jun, 2011 at 10:22:49am
I seem to remember that it was an Autronic ECU which are pretty good and tend to be sequential.
9th Jun, 2011 at 10:26:15am
It was discussed here:
9th Jun, 2011 at 11:32:28am
Paul s cheif inspector of the injection police! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th Jun, 2011 at 11:55:53am
That thread above started just over 4 years ago..... Long before my time on the forum and quite a while before Jean made the MS2 code fully sequential and siamese variable.
9th Jun, 2011 at 09:59:43pm
and its been running since then cant be all bad. I run a supercharger and I don't care the TB is on the wrong side.
9th Jun, 2011 at 10:49:58pm
And allegedly over 200bhp! If something is worth doing, it's worth doing half of. |
10th Jun, 2011 at 09:47:39am
Allegedly is the magic word. On 13th Jul, 2012 Ben H said:
10th Jun, 2011 at 09:56:53am
indeed! |
10th Jun, 2011 at 03:53:03pm
probibly a figure spat out of one of those calculator spread sheets. Not unlike a certain prominant employee of Moss Europe and his 180hp supercharged car. And likewise, looks like it crashed through Moss Europes stock room. On 26th Oct, 2004 TurboDave16v said:
10th Jun, 2011 at 04:51:47pm
LOL,
On 10th Jun, 2011 Sprocket said:
probibly a figure spat out of one of those calculator spread sheets. Not unlike a certain prominant employee of Moss Europe and his 180hp supercharged car. And likewise, looks like it crashed through Moss Europes stock room. On 28th Aug, 2011 Kean said:
![]() 161 Posts Member #: 6857 Advanced Member Lieto / Finland |
18th Jun, 2011 at 07:56:47pm
I saw this car in Denmark at IMM 2007.
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
16th Aug, 2012 at 07:58:25am
Again:
16th Aug, 2012 at 08:42:43am
Keep us posted on the progress V . . Viking is not my forte
