| Home > Help Needed / General Tech Chat > How many valve stem seals? | |||||||
1st Apr, 2005 at 09:22:00pm
How many valve stem seals should they be? I only have 4 on mine is that right? Theyre only on the larger valves, i think they are the inlet ones? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
1st Apr, 2005 at 09:32:58pm
you should only have 4 (one on each inlet) and none on the exhaust Team www.sheepspeed.com Racing
1st Apr, 2005 at 09:33:58pm
4 on the inlets,if its a turbo head they wont fit on the exhaust valves to good as the stems are .9 mm bigger dia
1st Apr, 2005 at 09:41:02pm
Thankyou :) they look a bit worn glad im replacing them thanks jim and dangerous Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
2nd Apr, 2005 at 07:24:27am
when i had my n/a head done for my 1380 i went for 8 valve stem seals
1171 Posts Member #: 107 Post Whore Sunny Sussex |
2nd Apr, 2005 at 10:03:37am
y i got 8 too, do they melt on the exhaust stems?
2nd Apr, 2005 at 10:46:39am
No they don't melt.
2nd Apr, 2005 at 12:57:48pm
here's a bit ere
2nd Apr, 2005 at 07:50:46pm
when i had them on all 8 of mine they used to stick on the exhaust valves and ride up and down doing nothing neway. apparently its only the intakes you need them on because the inlet valves suck oil through on vacuum.
2nd Apr, 2005 at 08:08:21pm
yeah but even if they do go up and down with the valve they'll still stop the oil running down the stem |
3rd Apr, 2005 at 08:55:57am
a little bit of oil down the exhaust stem does no harm as it will aid lubrication a bit on a already hot exhaust valve.
