Home > Help Needed / General Tech Chat > Turbos and Mirage
gdowle
Member #: 9534
Toronto, Canada
Hi, does anyone have a list of turbos and from what vehicles that will fit on mirage manifolds? having troubles finding a t2 from an r5.
gdowle
Member #: 9534
Toronto, Canada
is this suitable? http://cgi.ebay.com/ebaymotors/GT25-Turbo-...s#ht_6910wt_760
jamie@thefatgarage
Member #: 9345
Sheffield
It's a cheap shit chinese bag 'o' crap copy. So no.. not really. On the question of is a T25 the same flange, yes it is. Buy a proper garrett and recon it.
gdowle
Member #: 9534
Toronto, Canada
right o. is the gt1752 any good for my 998 or too big?
jamie@thefatgarage
Member #: 9345
Sheffield
Not an expert on the small bores. It's certainly better than a T25.
GT17 is good for poer on a 998, but not so good if you want a decent boost threshold.
almichie
Member #: 2065
When do you need it? I'm building my new engine and will be taking off my t2 in the next 4 weeks...
Shaft seems nice and snug
scott the joiner
Member #: 9229
newcastle upon tyne
Almichie I mite be interested in the t2 pm me when its off with some details if its not already sold thanks
gdowle
Member #: 9534
Toronto, Canada
pm'd
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
has anyone tried these turbos from china?
16V project underway
jamie@thefatgarage
Member #: 9345
Sheffield
I know of 4 fitted of which 3 failed within about 5000 miles. The 4th is on a very low mileage car. You can tell they are rubbish as soon as you see one up close. The metal is soft, the finish is poor, hence the price. If your turbo is easy to change then you can buy at least 5 for every pukka Garrett, so if you don't mind swapping them all the time, who knows, maybe they work out good value. I won't be using them though, specially not on anything that will run a lot of boost. The other problem is flanges, they never seem to quite fit and you end up modifying things, never a good sign on a precision bit of kit. As far as outright performance, they are close enough to make measuring the difference unnoticeable from other plain bearing units. Ball bearing turbos are way better, but cost £££.
danb41
Member #: 9285
Oxfordshire
Out of interest, where are the 'pukka' garrett turbo's made? Is the place they're made the only way to identify this?
dan.
jamie@thefatgarage
Member #: 9345
Sheffield
dan.
http://www.turbobygarrett.com/turbobygarre...tt_history.html
Best way to tell... if it's £200-£400 and brand new it's not a Garrett. Look up prices for the genuine article (GT25R / GT28R both circa £700), search for dealers on Google. The prices vary a little country to country but not by much when you include import duties. Some of the little ones used on diesels are a bit cheaper. Secondhand prices vary a lot, but £200 will get you something reasonable.
