Home > Help Needed / General Tech Chat > Diff Shims
SumpNut
Member #: 28
Right ive been searching and can only find one topic on the site related to diff shims
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3740
It didnt help..... Nor did my haynes manual - all that says in the stripdown section is to take the old ones off and put them back when you are rebuilding, doesnt atually say how to shim up the diff.
So how do I do it properly?
I only ask cause the diff i have just rebuilt didnt have any on at all. I do have some spare off an old gearbox but didnt just want to put them on, thought it was best to check first.
Cheers Guys
Dan*surprised*
Dangerous
Member #: 417
Its in the haynes book,basically you bolt the rear cover on loose and measure the gap under the tangs on the side covers
SumpNut
Member #: 28
ive found it in an older haynes book, for some reason the first one i looked in didnt have any gearbox info at all, the older one has all the stripdown info for the gearbox
Yes that is common, the newer Haynes is rubbish and hardly tells you anything about more involved stuff. Mini one is bad, early one tells you about full gearbox strip and rebuild. Peugeot 205 manual is the same as well, later one crap.
turbo hogster
Member #: 178
stowmaket suffolk
if i remember right its a 2-3 thou preload.
eg measure the gap with one gasket on, fit the other side cover with out one, measure your gap between the bearing and tang then measure your gasket.
so if the gap is 14 thou say, your gasket is 11 thou which gives you a gap of 3 thou then add the 3 thou preload then that means you want 6 thou of shims.
but the preload is only a guess as i always look before i carry this out as the mind is not always clear after a few lemon sherbets.lol
If you have got it, "How to Modify your Mini" by Dave Vizard also has a good description of how to shim the diff.
