Home > Help Needed / General Tech Chat > turbo water feed? now boost Q
eden7842
Member #: 8852
leicestershire
just mocking up my gt17 and thought to use the drain plug on the back of the block to tap into for a feed for the turbo.
i carnt any reason for it not to work and i should help to give a little more flow around #4
has it been done?
whats everyone's thoughts on this?
Edited by eden7842 on 5th Dec, 2011.
as long as the return is after the thermostat, or any other low pressure part of the cooling system, cant see a problem
eden7842
Member #: 8852
leicestershire
could i use a metro sandwich plate and put the stat below?
Craigie-B
Member #: 9468
Wootton Bassett
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=447369
I was told just to use a metro thermostat housing and return the water to that
eden7842
Member #: 8852
leicestershire
Wats the stock actuator capable of?
