Home > Show Us Yours! > Pic request: coilpack/edis locations
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys!
Just wondering where you guys have located your coilpacks/edis modules oh and where abouts in the cabin you guys put the megajolt?
Can you tell me which set of ht leads you got aswell with your setups
Thanks!
Craig
Edited by Craigie-B on 18th Dec, 2011.
Amp
Member #: 7856
Have a look at these two links:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=418538
and
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=427588
For pickmeup's solution, I don't think they ever came about in the end though! I knocked one up (poorly) which uses the same mounts from my old seat runners!
Megajolt i've seen put in gloveboxes or around that area, but can't find any pictures at the minute
Edited by Amp on 18th Dec, 2011.
pickmeup
Member #: 1200
yeah i think the price i was getting quoted of 40quid each didnt make it reasonable unfortunately, mine is still doing well on my car, you can make a simple bracket using some ali sheet if you not interested about it being all bling :)
mybe a pic in my build thread my coilpack is next to the wiper motor with ford KA leads there really long well longest stock ones ive found
megasquirt is under the dash passenger side
Craigie-B
Member #: 9468
Wootton Bassett
Excellent thanks So far guys *smiley*
Some old pictures but you get te idea
Edited by gr4h4m on 18th Dec, 2011.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
This is where I mounted my Edis unit
The coil bracket from Trigger Wheels.com
The coil fitted
I like the there out of the way of shit & grime.. Alan
Main Build
Upgrade to Turbo
Craigie-B
Member #: 9468
Wootton Bassett
excellent - thanks guys.
Alan which car are your ht leads from? Ka?
Thants where my coil pack is.
bennyy
Member #: 9037
Doncaster, yorkshire
My coilpack is in the corner of the bay, where the wiped motor sits but on the opposite side, the edis is mounted on inner wing, mj unit is on the inside of the glovebox .
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
It really doesn't matter where you place it. It just needs to be somewhere convenient so you can get the leads to reach and not get in the way of any pipework.
Personally I'd wait until you have everything else planned/in place before getting the drill out.
Mine is on the inner wing with the edis inside the car...
Wintersurfer has his on the front of the block. You can just see it here...
Craigie-B
Member #: 9468
Wootton Bassett
Ok thanks for the ideas *smiley*
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
Similar to everybody elses I suppose;
Leads are custom made from Canems, about £45 inc P&P http://www.canems.co.uk/catalog/index.php?...products_id=196
Megajolt unit just underneath the dash:
nala56
Member #: 9661
The plug leads were in the kit I bought from trigger wheels, dont know if they were made up by them, or if they were off some other car like ford fiesta, thats where the coil and enis unit comes from, along with other ford models.. Alan
Main Build
Upgrade to Turbo
