| Home > General Chat > Stuck Nut. | |||||||
3rd Jan, 2012 at 07:32:22pm
This weekend I had a stuck pinion nut, in a gearbox I dont need, so one new breaker bar and 1.30hrs later, also now my abseiling rope is 1m shorter I have started posting on Instagram also my name on there is turbomk1golf
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
3rd Jan, 2012 at 07:36:24pm
its only a bodge if it fails!
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
3rd Jan, 2012 at 07:36:37pm
Looks standard practice to me fella, have you bent that pole in the lawn?
3rd Jan, 2012 at 07:37:12pm
Had mine upsidedown in a vice before now. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
3rd Jan, 2012 at 07:41:43pm
I bolt mine upside down on my bench, Ive seen some put the box under the wheel of a car I seriously doubt it! |
3rd Jan, 2012 at 07:50:45pm
On 3rd Jan, 2012 paul wiginton said:
I bolt mine upside down on my bench, Ive seen some put the box under the wheel of a car I combined rebuilding the defender hubs with dismantling a mini gearbox
Edited by minimole23 on 3rd Jan, 2012. On 7th Oct, 2010 5haneJ said:
3rd Jan, 2012 at 08:07:26pm
On 3rd Jan, 2012 Carlzilla said:
have you bent that pole in the lawn? Looks a bit on the piss lol, Yes its on the piss now O well its not mine. I had it bolted down to the bench, but i pulled the bolts thought the wood need to stay out of the gym.
3rd Jan, 2012 at 08:11:44pm
torquing it back up, i have an advantage i think im heavy as fook Edited by Brett on 3rd Jan, 2012. Yes i moved to the darkside |
3rd Jan, 2012 at 09:05:03pm
I used my work car to hold mine down, I tried standing on it but ended up lifitng myslef up and twisting my ankle. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
3rd Jan, 2012 at 09:09:14pm
i have come a cross many pinion nuts locktighted on by some buffon in the past reconditioning them ...i have dropped on ...... a bastard to get off to say the least
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
4th Jan, 2012 at 12:59:05am
Blimey, some great lash ups !
4th Jan, 2012 at 01:33:25am
Four bolts through the dowel holes into anchor bolts in the garage floor concrete, with some thick penny washers between, 3/4" drive 4 ft breaker bar. Never had a problem. On 26th Oct, 2004 TurboDave16v said:
4th Jan, 2012 at 01:42:25am
4th Jan, 2012 at 08:29:12am
A surgical 2x4 shoved into the gearbox and lever downward. Piece of piss! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
4th Jan, 2012 at 09:09:21am
On 4th Jan, 2012 MikeRace said:
A surgical 2x4 shoved into the gearbox and lever downward. Piece of piss! I learn't from the master. lol. Sometimes needs somebody stood on the end. My chosen plank is about 4 - 5 feet long. Wifey is usefull from time to time. On 11th Feb, 2015 robert said:
4th Jan, 2012 at 09:27:50am
I do what mike does.
4th Jan, 2012 at 11:08:18am
Standing on it does not work. If you think it does, then your torque wrench is faulty.
![]() 207 Posts Member #: 9045 Senior Member Wolverhampton, West Midlands |
4th Jan, 2012 at 08:45:52pm
Just stick mine under the 4 poster ramp, I have had bastards though. Ive bent breaker bars, jumped up and down on scaffold poles the lot. Patience is the key, they come undone eventually. |
4th Jan, 2012 at 09:02:11pm
Colin / Vegard i hate to say it but i disagree with you both
4th Jan, 2012 at 09:54:47pm
On 4th Jan, 2012 Brett said:
Colin / Vegard i hate to say it but i disagree with you both and why would my torque wrench be faulty? Fair enough but you might have fallen off said box and twisted your ankle That input gear nut doesn't have much on it and easilly slips. The pic made me giggle though
Why struggle applying 150lb or more of force on the bar you are using in that pic. You'll give your self a hernia bent over and crunched up like that, You'll only do that the once, when you only need to apply 50lb with a fairly cheep tool of choice and another way to hold the box, simple made tool that bolts to either the speedo housing or transfer housing fixings for one. On 26th Oct, 2004 TurboDave16v said:
