Home > General Chat > Best way to get aluminium engine parts clean.
danb41
Member #: 9285
Oxfordshire
Trying to get my transfer casing clean. I've had good results with a wire brush attachments on drills. But with the transfer case there are a lot of very small crevices that i can't get to!
Is there a chemical that would be effective? Or is bead/shell blasting the only option?
Dan.
oli79
Member #: 8480
I bead blasted mine
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
bennyy
Member #: 9037
Doncaster, yorkshire
I used gunk on mine get them clean then spray them with aluminium spray paint.
Here's a few pics
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Swarfeager (sp) de greaser and a scrubbing brush mine came up like bennys but no paint
When i did my old carb i used tool de-greaser, next i used auto sol and wire wool, for the final step i used small wire wheels on a dremel came out shiney as fook few little bits missed but good enough for what it was in lol.
When i get to the stage of building my motor up at some point all bits will be dressed to loose weight like paul w this will also bring out a nice finish *smiley*
Mr Joshua
Member #: 1954
Luton Bedfordshire
Dishwasher. Put my block, gearbox case and transfer case in the dishwasher they came out spotless *Clapping*
Own the day
Chalkie
Member #: 9764
Northamptonshire.
+1 with the dish washer!! Grand rents were not impressed but i was with the block and clutch housing
Johnny
Member #: 6926
Accrington
i used degreaser and a jet wash.
jlay
Member #: 1742
essex
as said degreaser then i steam clean. on bits that wont come up i do have access to bead blasting this done well is so delicate.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Chalkie
Member #: 9764
Northamptonshire.
have them bead blasted then have them annadised :)
danb41
Member #: 9285
Oxfordshire
Cheers guys, a few more methods to keep me busy!
