Home > Help Needed / General Tech Chat > To all using 2WD cossie intercoolers
danb41
Member #: 9285
Oxfordshire
How are you mounting these? Its all a bit tight, and i don't want to go hacking the brackets off it before i know the best way to mount it!
Pictures would be greatly appreciated!:)
Dan.
Amp
Member #: 7856
Have a search for Benny's project, I think he used the 2WD one!
bennyy
Member #: 9037
Doncaster, yorkshire
i never mounted mine, just placed on the altenator and oother side was held up with the hose.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
danb41
Member #: 9285
Oxfordshire
Ah ok Benny, and you didn't have issues with the boost hoses coming off? Was that set up with a T3?
This is how I had mine on the frog:
a
bennyy
Member #: 9037
boost hose came off the start with, but thats just because i cut the take off down too short, tom fenton built it up and put a bead around the edge and never had a problem again upto 18psi, never rattled or knocked either.
Mine is / was mounted llink in my sig the top and bottom plates are solid and can be drilled and tapped.. the core is thin and delicat dont drill through that lol
My mountings snapped after an incident on boost cut @30psi though.. :(
Alex your.end.tank over the thermo housing is exactly what i could do with i may have to steel that idea *wink*
welshdan
Member #: 1111
s wales
Made some small brackets for mine, should also be on my build thread.
these are my mountings mk1, i changed the 2 tubes for a sheet of ally that extended from the head studs to the slam panel mainly to help reduce heat soak. squashed tubes are literally screwed into the intercooler
the whole intercooler sits on/ bolts to the sheet ally in the last pic but now thats broke i will go back to the initial design with the tubes and some fibreglass ducting the whole intercooler will be essentially in its own little world *happy*, air in the front and out the top
Edited by Brett on 27th Aug, 2012.
danb41
Member #: 9285
Oxfordshire
Thanks guys, i think i will get hold of some tubes like your mk1 design Brett.
Been thinking I might drop mine right down where the number plate is and have the outlets coming straight out sideways so as not to foul the subframe but not got further then that.
danb41
Member #: 9285
Oxfordshire
Also mine has modded end tanks. So the rad side is vertical. It seems it will be blooming tight with regards to shutting the bonnet! As i have a riser plate on the thermostat too. *oh well*
Get a different cooler then, or modify the end (again) and route the pipework through the inner wing?
J99UNK
Member #: 9469
letchworth herts
Alex who modded your end tanks on ur intercooler ?
Phil @ http://gsmotorsport.net :) Tell him I sent you!
J99UNK
Member #: 9469
letchworth herts
Thanks how much did it cost to get a idea of what it going to cost
I don't know - It was done as a part of a bigger job, and it was also done with a bit of wheeler-dealering *wink*
