| Home > Technical Chat > Turbo EFI setup Off the Shelf | |||||||
193 Posts Member #: 510 Advanced Member Malta |
8th Jun, 2005 at 12:04:55pm
Hello people, I donated, but somehow didn't get the label! :( |
8th Jun, 2005 at 12:18:28pm
Sounds good on paper. However thinking that you can get rid of rolling road time is not possible. Even with all the sensors you mention, the ECU needs a map to use as a reference to look up the correct injection timings and values for whatever. In order to define this (and the associated ignition map) you will still need rolling road time. In addition, any small change in exhaust or cylinder head, valve sizes etc would mean the map created would not work effectively on the different engine, like swapping an SU from one engine to another, it will not be optimal for both.
Edited by Tom Fenton on 8th Jun, 2005.
8th Jun, 2005 at 12:21:50pm
There seems to me (with my limited Knowledge!) to be only one route to this solution, and that is to go to a head with seperate inlet ports, the cheapest purpose built head is the AKM 7 port which has the benefit of a std turbo exhaust system, or to find a head rom somthing else (like the BMW K1100 bike head) On 28th Aug, 2011 Kean said:
8th Jun, 2005 at 12:38:34pm
In all fairness we get very few stories of blow ups on here!!
AlexF |
8th Jun, 2005 at 12:40:32pm
Yes I agree, the only real problems people have had, have been fairly tired old engines that had not been rebuilt giving up the ghost? Well what do you expect? And most people who had this were not suprised and knew it would probably happen at some point
8th Jun, 2005 at 01:23:37pm
All very true people... Re the rolling road avoidance, true you cannot do much about it, unfortunately (we dont have any in Malta, so we're used to working without them). The idea actually is to use as many off-the-shelf parts as possible (eg. Cosworth injectors, Emerald ECU, Mini mpi fuel tank + pump, sensors from other vehicles, Mirage turbo manifold) which would leave us with very few bits to be fabricated - i.e. inlet manifold. Then we get to the software part - that's where previous experience of some people here comes handy. Couple this knowledge with some dyno time Some tuners will be interested because they can then optimise (and sell) a head for this setup...
8th Jun, 2005 at 01:41:03pm
lol!
AlexF |
8th Jun, 2005 at 01:55:06pm
I really don't think there is that much interest to be honest - not when you start adding up all the costs involved.
Edited by turbodave16v on 8th Jun, 2005. On 17th Nov, 2014 Tom Fenton said:
8th Jun, 2005 at 02:28:51pm
You can get the 7 port and a set of 45's in with no bonnet bulge. if running injection, you could use shorter throttle bodies and still have room for a plenum. But in all honesty a single injector should be easier to setup and still give good running due to less overlap on a turbo motor, the fueling issues are more problematic as cams get "hotter" Just set the mixture with a lambda sensor. I'd be more worried about gearbox reliability than sorting out the engine fueling. On 28th Aug, 2011 Kean said:
8th Jun, 2005 at 02:31:50pm
On 08/06/2005 14:28:51 mini13 said:
I'd be more worried about gearbox reliability than sorting out the engine fueling. 5 odd seconds on full boost very lean = no more pistons! Alex AlexF |
8th Jun, 2005 at 02:45:47pm
I've heard gearbox reliability is quite good with no pistons? LOL!!!
8th Jun, 2005 at 02:51:11pm
Point taken...
8th Jun, 2005 at 04:13:36pm
Mini13 - why on earth would you bother with throttle bodIES on a 7 - or even 8 - port turbo engine?
9th Jun, 2005 at 08:22:12am
OK, so who would be interested in a 7-port? Maybe I'ld twist Minisport's arm a little and get a good discount on a big order... I donated, but somehow didn't get the label! :( |
9th Jun, 2005 at 08:30:18am
Worth a try. Although in the past they wouldn't even send me a free bloody sticker with an order. Demon Tweeks are the same.
9th Jun, 2005 at 11:23:37am
Dave, sorry wasn't being very clear was I,
9th Jun, 2005 at 11:26:03am
Dave and carl austin did put a MG metro and Mg Turbo inlet on a flow bench, I recall the results being supprisingly close, but I'm sure dave or carl will be along shortly with more details Team www.sheepspeed.com Racing
9th Jun, 2005 at 01:21:50pm
Thanks jimster,
9th Jun, 2005 at 11:21:15pm
please let me know on the size of a 7port discount, im fancying one but doubt i can afford it at the mo |
10th Jun, 2005 at 09:01:21am
I'll check. I usually manage something like 10%... but they're still developing the head so no prices are out yet.
11th Jun, 2005 at 09:25:25am
I cant reveal the source, but he's a very well-known Mini tuner. However, he has connections with MS's competitor, so he could be slightly biased... read the Vizard article on the 7-port and it looks promising nonetheless... I'll have a word with Minisport and we'll see... I donated, but somehow didn't get the label! :( |
21st Jun, 2005 at 10:05:01pm
On 11/06/2005 09:25:25 MaltaMini said:
I cant reveal the source, but he's a very well-known Mini tuner. However, he has connections with MS's competitor, so he could be slightly biased... read the Vizard article on the 7-port and it looks promising nonetheless... I'll have a word with Minisport and we'll see... I know some one running this 7 port and it gave precisely 3bhp more but turned a cammy b***ard car into a driveable torquey one! On 5th Sep, 2011 Vegard said:
