| Home > Help Needed / General Tech Chat > Diff bearing inner race removal from Crown wheel | |||||||
809 Posts Member #: 224 Post Whore Katy TEXAS |
5th Jan, 2013 at 05:15:04pm
Alright guys,
5th Jan, 2013 at 05:32:18pm
Just to say I just removed my swiftune heavy duty diff bearing no trouble at all from the crown wheel on my quaife, with a 3 leg puller....
5th Jan, 2013 at 05:45:33pm
Ive ground through one side of the inner race to free them a few times before I seriously doubt it! |
5th Jan, 2013 at 06:31:52pm
As Dave says. Grind down to near the i/d of the inner race. You know when you are close as the material gets thin and starts to go blue/yellow colours with the heat from the grinder. Once it is thin enough it will yield and allow you to tap if off with a chisel or wedge down the back, without having to go right the way through.
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
5th Jan, 2013 at 07:31:12pm
Bearings are very brittle, need I say more |
5th Jan, 2013 at 07:34:01pm
I also ground mine until thin to remove.
In the 13's at last!.. Just |
5th Jan, 2013 at 08:05:54pm
I have a special chisel. Always gets them off, occasionally needs a little bit of fire to help it on it's way. On 11th Feb, 2015 robert said:
5th Jan, 2013 at 08:17:38pm
http://www.ebay.co.uk/itm/2-x-12-TYRE-LEVE...=item3ccc448489 On 26th Oct, 2004 TurboDave16v said:
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
5th Jan, 2013 at 09:53:41pm
I put an exhaust clamp around the bearing race, a thick washer on the crownwheel and use a three legged puller.
Metric is for people who can't do fractions. |
6th Jan, 2013 at 01:49:47am
Alright Gents,
Edited by Brocky on 6th Jan, 2013. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
6th Jan, 2013 at 10:09:55am
I use a old diff, output shaft and smal puller... :)
[X] nail here for new monitor |
6th Jan, 2013 at 03:40:32pm
Cool,
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
7th Jan, 2013 at 06:05:09pm
Good call that mate, I like it just takes brains will remember that one, thanks for sharing. Alan
On 6th Jan, 2013 Brocky said:
Alright Gents, Thanks for all the suggestions and help :) I did look at my grinder, and then I looked at my half built gearbox and block on the bench, then looked at the rain outside.... Not wanting to grind in doors near the new build, and whilst waiting for the rain to stop I realized that the standard outer race can be refitted fairly easily the wrong way around complete with ball races, thus giving a shoulder to pull on. The only trouble was that you have to remove the crown wheel retaining bolts first, which means you then have to have some thing for the 3 leg puller to react against in the center. I spotted my flywheel puller and hey presto cleanly removed a very stuborn inner race (which has been is place since 1979, but only 27k miles box)....although did go with quite a "crack" initially. I actually think the bearing could be reused in a standard application, as still seems smooth and happy, All in all quite pleased with my self lol:) Ps like all the other ideas, especially the tyre levers / exhaust clamp, the chisel method has always been my prefererred but this seemed quite clean even as a last resort in this case. Also I think if I had a short peice of round stock that would fit inside the ID of the inner race this would also be a suitable reaction point, for future reference. Cheers Brocky Main Build
