| Home > Help Needed / General Tech Chat > Help getting it started! | |||||||
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
17th Feb, 2013 at 01:57:52pm
So today i'm trying to get the mini started, got it turned over and got oil pressure.
Edited by danb41 on 17th Feb, 2013. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
17th Feb, 2013 at 02:16:13pm
I reckon you could be about half a mill out of centre, but if the plugs are firing when they are out of the bores it sounds like some thing else, are the plugs getting wet with fuel?.. Main Build
17th Feb, 2013 at 02:18:19pm
Yeah it's not a lot nala, but it makes it tricky trying the sensor closer as it could hit. The plugs are fine, i've been turning it over with the fuel pump disconnected for most of the time to prevent this. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
17th Feb, 2013 at 02:20:30pm
Clean the crank.sensor. had swarf on mine stopping it from firing up |
17th Feb, 2013 at 02:23:07pm
It's clean dan, i will have to check the wiring again. Is the trigger wheel being off centre not really an issue then? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
17th Feb, 2013 at 02:28:17pm
The settings for the senser gap are half to one mill, make sure your getting fuel to the engine, before and after the carb.. Alan Main Build
17th Feb, 2013 at 02:31:39pm
If your trigger wheel is out, could cause erratic or rough running.. Alan Main Build
17th Feb, 2013 at 02:33:44pm
Cheers Alan, just a bit miffed as to why it's not getting a spark. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
17th Feb, 2013 at 02:40:46pm
How do you know your not getting a spark when the plugs are in the cylinder head?.. Edited by nala56 on 17th Feb, 2013. Main Build
17th Feb, 2013 at 02:47:56pm
With all plugs in the cylinder head and spare plug in the ht leads earthed to the head bolts. Should emulate them in the cylinder head.
17th Feb, 2013 at 02:58:55pm
That sounds like a weak spark then, do you know how far the trigger wheel is out of centre.. Main Build
17th Feb, 2013 at 03:20:43pm
At it's closest approx 1/2 mm and at its furthest point approx 1 mm. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
17th Feb, 2013 at 03:27:42pm
Like I say mate .5 to 1 mill is ok.. that information comes from trigger wheels instruction sheet that I got when I bought the megajolt kit.. Main Build
17th Feb, 2013 at 03:34:18pm
Ok that's good then! Just what's causing week/ no spark when cranking speed is low?
17th Feb, 2013 at 03:36:57pm
Yes
Main Build
831 Posts Member #: 908 Post Whore gateshead |
17th Feb, 2013 at 03:37:26pm
make sure your using new/decent fuel, static timing out maybe?, balls to the blower!!!
17th Feb, 2013 at 03:38:16pm
New fuel this morning stu. Could you explain the static timing? My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
17th Feb, 2013 at 03:48:10pm
Set the engine to top dead centre on compression stroke with the missing tooth at 12 oclock, count back to the 9th tooth your senser should be set to the centre of that tooth.. Alan Main Build
17th Feb, 2013 at 04:00:51pm
Have a look at this mate..
Main Build
17th Feb, 2013 at 04:06:13pm
Cheers Alan, that's all checked an correct. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
17th Feb, 2013 at 04:30:28pm
Right we have tried feeding the coilpack with it's own battery, and this has made a much better spark. But still no starting! My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
17th Feb, 2013 at 05:58:43pm
I have checked the static timing and at tdc the missing tooth is inline with the sensor. Which is in position with the triggerwheels bracket. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
17th Feb, 2013 at 06:21:24pm
At TDC the missing tooth should be 90 deg after the sensor shouldn't it? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
17th Feb, 2013 at 06:50:23pm
there is a fault here dan, i suspect a bad connehing or duffed coil pack and or incorrect wiring..... you will have to go over your work buddy ..... and then start looking at faulty items ?
17th Feb, 2013 at 07:15:50pm
thats not right mate, missing tooth at the top, senser should point to the 9th tooth back
On 17th Feb, 2013 danb41 said:
I have checked the static timing and at tdc the missing tooth is inline with the sensor. Which is in position with the triggerwheels bracket. Main Build
