Home > Help Needed / General Tech Chat > Engine stabaliser
1275min
Member #: 538
Frimley, Surrey
Hi Guys,
Just a quick one, how many engine stabilisers do you have?
At the mo I've got one really heavy duty beast on the top right of the engine with a mount welded to the bulk head. Wondering if I need another at the bottom on the left where the original ones were to get it through the Mot.
shellspeed
Member #: 9580
Surrey
2 at the top and 3 at the bottom.
Have an internal shift so needs to be nice and steady or it will jump out of gear under acceleration/lift off the throttle.
Generally just two at the top. One in the standard position, one one the thermostat or waterpump.
One at the top and 2 at the rear bottom. will add more to the front bottom if needs be
2 top 2 bottom.
Hehe. You said bottom.
Quadruple penetration.
dig-mini
Member #: 9269
Rotherham
2 and 2 but not going to say bottom in case john is around
Craig
chinlesswonder
Member #: 1192
In the garage......again!!
1 at top 3 at bottom
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
My old n/a 1275 had two top and four on the bottom, came like it and kept with if *smiley*
charlieb150
Member #: 9931
brighton
1and1 oops
smiffy_no46
Member #: 8079
York
1 top in the std position, 3 underneath (std one going forward and 2 going back) All rose jointed and on solid engine mounts. Nothing should move far!
jonny f
Member #: 9894
Dorking
Sounds like i need an extra one on the internal linkage.
So far i have a solid one in the standard place, DSN thermostat one and a solid front one. Yet to drive it.
i have 2 lower and one solid banana shaped upper, still need to change that *crying*
what ever you run... use the one peice rubber MPI steady bushes, they are really good! minispares do an uprated one which is what I use and they are bomb proof.
I run the std top one and an avon bar/moss one that bolts to the waterpump, on the gearbox I use te minispares ones that go from the back of the gearbox to the sub frame.
I also use the MPI bushes on the lower steadys, you have to drill them out to fit though... taking care not to get the steel centre peice hot and cook the rubber.
danb41
Member #: 9285
Oxfordshire
These ones Joe? http://www.minispares.com/product/Classic/....aspx|Back%20to
thats the fuckers!
KKF101320 are the std ones,
KKF101320EVO are the uprated ones.
