| Home > Technical Chat > Wiring loom info | |||||||
19th Aug, 2013 at 09:24:39am
I have been thinking of redoing my loom for a long time now as mine let's just say is Dog Shit.
Edited by madmk1 on 16th Feb, 2014. I have started posting on Instagram also my name on there is turbomk1golf
19th Aug, 2013 at 09:34:32am
I used 1mm thin wall for all the normal stuff. I have some pages etc at home with all the standard lucas colours in it. Will try and sort it tonight. On 11th Feb, 2015 robert said:
19th Aug, 2013 at 09:38:33am
Top man! I have started posting on Instagram also my name on there is turbomk1golf
19th Aug, 2013 at 09:45:02am
You need to work out current draw for each item, size the wire at say [plus 20% of max current draw then fit a fuse at a suitable rating to protect the wiring.
19th Aug, 2013 at 09:50:04am
The main thing to think about really is power distribution and a fuse and relay box.
19th Aug, 2013 at 10:00:20am
I've used this fuse box on my car with a separate one to supply the three main circuits.
19th Aug, 2013 at 10:26:59am
I've started drawing up a loom for mine ages ago. See if you can find a coloured wiring diagram online, it's pretty much the same colours throughout the board on minis. I can look at a wire and know exactly where it goes and what it does on 80's looms now, but I couldn't list them all off the top of my head. Look at a Haynes too and study the wiring diagram closest to your needs, helps loads.
Edited by Carlzilla on 19th Aug, 2013. On 26th Jan, 2012 Tom Fenton said:
19th Aug, 2013 at 10:34:58am
I see what your saying Tom this is why I have been thinking about it long and hard lol.
19th Aug, 2013 at 10:39:09am
I've seen things wired in bell flex and speaker wire and all sorts in minis, I'm sure most of you have. And then some wonder why things start setting on fire. I personally don't think some of the mini loom is up to the job, So wiring sizing is of great importance, if in doubt, oversize. On 26th Jan, 2012 Tom Fenton said:
19th Aug, 2013 at 10:42:04am
I think I could just keep this updated as I go, as I did not really find much info on here. I have started posting on Instagram also my name on there is turbomk1golf
19th Aug, 2013 at 11:09:22am
Indicator/hazard wiring diagram if it helps at all Si http://www.turbominis.co.uk/forums/index.php?p=vt&tid=521244 On 26th Jan, 2012 Tom Fenton said:
![]() 580 Posts Member #: 9580 Post Whore Surrey |
19th Aug, 2013 at 11:28:47am
19th Aug, 2013 at 11:41:37am
On mine the car wiring and the engines wiring is seperate then the cars is split
Edited by Brett on 19th Aug, 2013. Yes i moved to the darkside |
19th Aug, 2013 at 05:12:41pm
On 19th Aug, 2013 Tom Fenton said:
You need to work out current draw for each item, size the wire at say [plus 20% of max current draw then fit a fuse at a suitable rating to protect the wiring. Say a pair of dipped beam headlamps are 55w each so 110w the pair. P=I.V so Power in Watts = Current in amps (times) Voltage in Volts Work that round backwards and you end up with I=P/V So nominal current for our example equals 110w/12v Which equals 9.16 Amps. To give a bit of headroom add 20% equals 11 Amps. So you would go for the next size cable up, say 15A cable. Fuse wise you want the fuse to blow before the cable reaches its max capacity. In this example you are bang in between. I would probably try a 10A fuse and see if it lives, if it does not you would have to go up to a 15A. In most cases the 10 amp fuse would be fine, since the fuse is rated to carry 10 amps continuously. In any case with the alternator running the voltage will ve ~14.5 therefor the amps will be less anyway. Also see the attached standard wiring colour chart. Maybe not so much used now, but back in the day it was fairly common on all British manufactured cars at least Edited by Sprocket on 19th Aug, 2013. On 26th Oct, 2004 TurboDave16v said:
19th Aug, 2013 at 05:20:21pm
Awe crap, lol the attachment management tool didn't work On 26th Oct, 2004 TurboDave16v said:
19th Aug, 2013 at 07:03:44pm
Try looking up Lucas wrist as they built a lot of the looms for British cars and may have all the spec data available. Own the day
16th Feb, 2014 at 10:31:12pm
Right lads this is back to the front of my head again lol. So is there any How To web sites for thick Os I can read up on? As I think I will start from Scratch.
16th Feb, 2014 at 11:02:09pm
Simon get yourself one of these and follow the wiring diagram supplied with it.
17th Feb, 2014 at 02:16:53pm
17th Feb, 2014 at 02:30:35pm
Cool Andy !! I have started posting on Instagram also my name on there is turbomk1golf
2 Posts Member #: 9834 Junior Member California |
5th Mar, 2014 at 09:11:23pm
Simon,
i know VWP has a good website but when I have asked them it seemed like he was going safe if you know what I mean.
