| Home > Technical Chat > final drive | |||||||
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
19th Oct, 2013 at 11:41:44am
what final drive are you running on your turbo mini's.
19th Oct, 2013 at 12:17:25pm
I was running a 3.2 very good all rounder imo gaveit enough legs on the road and sseemed ok on track
Yes i moved to the darkside |
19th Oct, 2013 at 12:23:31pm
best set off in 3rd gear brett On 19th Oct, 2013 Brett said:
I was running a 3.2 very good all rounder imo gaveit enough legs on the road and sseemed ok on track This time I think its a 4.7fd.. could be wrong lol on 10s to ![]() What the mind can conceive the mini can achieve
19th Oct, 2013 at 12:33:21pm
Will have to see might launch in second and shift to 4th vtec will give it legs over the line I have the same gearing as crx I know running tens and a few hundred kgs less Yes i moved to the darkside |
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
19th Oct, 2013 at 12:38:45pm
I had a 2.9 for a while, was great for motorway journeys. I now have a 3.2 fd and find it a lot more enjoyable to drive. Its a great all rounder in my opinion! My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
![]() 178 Posts Member #: 10196 Advanced Member |
19th Oct, 2013 at 02:59:40pm
I like the 3.2 diff, worked well with 13's |
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
19th Oct, 2013 at 06:33:53pm
Mine is a 2.9 with 10 inch wheels. Not tried it yet but should suit the open roads in cornwall nicely |
19th Oct, 2013 at 06:48:11pm
Got a 3.7 in mine and its too short
19th Oct, 2013 at 09:31:12pm
3.44:1 in mine. It's great for what I use the car for.
In the 13's at last!.. Just |
20th Oct, 2013 at 12:11:27am
Edit: 3.2 using 10'' wheels, My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
20th Oct, 2013 at 07:12:27am
not yet run it but 2.95 on the club man close ratios works out at 100kph at 3k (4th) and 100kph at 5.5k (2nd)
20th Oct, 2013 at 08:26:26am
im using a 3.1 diff .
20th Oct, 2013 at 10:28:23am
looks like the general consensis is the 3.2 FD.
20th Oct, 2013 at 12:31:28pm
3.2 final drive came ONLY in the Metro turbo
20th Oct, 2013 at 02:14:21pm
I had a feeling that some spi minis also had the 3.2??
20th Oct, 2013 at 02:24:57pm
mine was out an spi and was a 3.2
20th Oct, 2013 at 02:43:19pm
SPI Coopers had a 3.2 FD too. If something is worth doing, it's worth doing half of. |
20th Oct, 2013 at 06:21:27pm
On 20th Oct, 2013 Tom Fenton said:
3.2 final drive came ONLY in the Metro turbo Certain 80's Minis came with a 3.105 final drive which is quite easy to get hold of and obviously pretty close to the 3.2 Ahem, Cough....... The 3.2 also came in the Mini Cooper Spi's
20th Oct, 2013 at 06:27:17pm
Too late Colin. If something is worth doing, it's worth doing half of. |
20th Oct, 2013 at 06:55:14pm
20th Oct, 2013 at 08:14:20pm
does anyone know how many teeth a 3.2 crown wheels has?
11th Nov, 2013 at 09:14:56am
if you haven't found out yet i believe its 19 and 61 to make 3.2
11th Nov, 2013 at 10:19:32am
yep all sorted now 19/61 On 11th Nov, 2013 Turbo This.. said:
if you haven't found out yet i believe its 19 and 61 to make 3.2 this is a site that someone kindly showed me long time ago figure it be a good place to post it for other to find it and hope fully get some use from it http://www.guess-works.com/Shop/Parts/display.htm?id=158 What the mind can conceive the mini can achieve
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
11th Nov, 2013 at 01:22:55pm
3.2s also came in late Metros with the economy drop gears. Got one sat under the bench now ready to be dismantled.
Metric is for people who can't do fractions. |
11th Nov, 2013 at 01:28:13pm
managed to soucre a 3.2 and going to use the clubman set in the turbo.
